No Sound Help!
Alright guys, I've been at this for about six hours and I am stumped. I have no sound coming from any jack on my computer via the onboard soundcard or the front jack. Ive uninstalled and reinstalled the drivers from my mobo's disk and went through the realtek website and tried every driver I could find there. The system recognizes the speakers and shows them as putting out sound, but I get nothing. I've even ran through the BIOS to make sure nothing was amiss there. Any help is appreciated.
5 answers Last reply
More about sound help
  1. Hi :)
    Specs would help.... ?
    All the best Brett :)
  2. Here's a rundown. I've got the digital audio from the 680 disabled and the only thing enabled is the speakers. I've tried every driver possible and i've had no luck
    Computer:
    Computer Type ACPI x64-based PC
    Operating System Microsoft Windows 7 Ultimate
    OS Service Pack -
    Internet Explorer 9.0.8112.16421
    DirectX DirectX 11.0
    Computer Name T-PC
    User Name t
    Logon Domain t-PC
    Date / Time 2012-04-11 / 07:52
    Motherboard:
    CPU Type QuadCore AMD Phenom II X4 Black Edition 980, 3700 MHz (18.5 x 200)
    Motherboard Name ASUS M5A88-V EVO
    Motherboard Chipset AMD 760G/780G/780V/785G/790GX/890GX, AMD K10
    System Memory 4096 MB (DDR3-1333 DDR3 SDRAM)
    DIMM3: Kingston HyperX KHX1600C9D3/2GX 2 GB DDR3-1333 DDR3 SDRAM (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
    DIMM4: Kingston HyperX KHX1600C9D3/2GX 2 GB DDR3-1333 DDR3 SDRAM (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz)
    BIOS Type AMI (09/20/11)
    Communication Port Communications Port (COM1)
    Display:
    Video Adapter NVIDIA GeForce GTX 680 (2048 MB)
    Monitor Asus VH242H [24" LCD] (A7LMTF123578)
    Multimedia:
    Audio Adapter Realtek ALC892 @ ATI SB800 - High Definition Audio Controller
    Audio Adapter Realtek ALC892 @ High Definition Audio Controller [10DE-0E0A] [NoDB]
    Storage:
    IDE Controller Standard Dual Channel PCI IDE Controller
    Storage Controller AB023CD4 IDE Controller
    Disk Drive ST31500341AS ATA Device (1500 GB, 7200 RPM, SATA-II)
    Optical Drive ATAPI iHAS324 Y ATA Device (DVD+R9:8x, DVD-R9:8x, DVD+RW:24x/8x, DVD-RW:24x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
    Optical Drive NALG FCTM7C5UB SCSI CdRom Device
    SMART Hard Disks Status OK
    Partitions:
    C: (NTFS) 1397.2 GB (1020.6 GB free)
    Total Size 1397.2 GB (1020.6 GB free)
    Input:
    Keyboard HID Keyboard Device
    Mouse HID-compliant mouse
    Network:
    Primary IP Address 192.168.1.106
    Primary MAC Address E0-46-9A-B2-17-78
    Network Adapter NETGEAR WNDA3100v2 N600 Wireless Dual Band USB Adapter (192.168.1.106)
    Network Adapter Realtek PCIe GBE Family Controller
  3. Did you find a solution to your problem yet?
  4. I never did. I got a new soundcard today and that fixed it up.
  5. Thanks for the reply. I was experiencing the same problem but got it to work shortly before commenting on this thread. Wanted to see if it worked for others.
Sound Cards Components
