I'm pretty green when it comes to decent video cards and need help with my settings.
I just upgraded to a semi decent gaming system it's a CyberpowerPC Gamer Ultra GUA140
Processor: AMD Phenom II x4 955 Black Edition / 3.2GHz Overclocked to 3.7
4GB DDR3 SDRAM (expandable to 8GB)
Hard Drive: 1TB (7200 RPM) Serial ATA-II, 4X DVD±RW Dual-Layer Super-Multi Drive ( P.O.S. JUNK !! )
AMD Radeon HD5450 512MB ( I replaced with a Saphire HD 6850 1-GB GDDR5
Genuine Windows 7 Home Premium (64-bit)
I also upgraded the PSU to a OCZ Fatal1ty 550 watt 80 plus certified Saphire Radeon HD 6850 requires 500+ and all runs good.
I ran the windows performance test with the HD5450 and the score was a horrible 2.9
With the new HD6850 card the computer scores
Processor 7.3
Ram 7.5
Graphics 7.7
Gaming Graphics 7.7
Hard Disk Drive 5.9
So the new card rocks and I need some help with the settings. I'm using my LG 47" LED 3D TV as my monitor and the card is displaying in 1920x1080 I bought some newer games but Counter Strike Souce and DOD source are my 2 favorites. Just a little reference the HD 5450 card scored 56 FPS when I ran the video stress test in Counter Strike and the HD 6850 scored 298.06 FPS so thats good but when I went into the advance settings for the video,there are a few things I dont understand. Theres a little * by what the game detects as the best settings for my system. Lets start with the antiasiling its set to none and has options for 2x,4x,8x MSAA why is my best setting none? What should I set it to?
Then theres the filtering its set to trilinear and has options of anisotropic 2x,4x,8x,16 what should it be set at?
Multicore rendering is set to disabled ? Can I set it to enablem if so whats the difference?
Motion blur is diabled is that good,bad or doesnt matter?Direct-X is Hardware detected as v9+ but the software is v9.0 ,My CPU system check says I'm running 11x is it the game that limits me to 9x ??
Finally I have a choke issue 103-130 what can I do to fix right now I have Rate 30000, CL_cmdrate 100,CL_updaterate 100,FPS_maxrater 100,CL_smooth 0,CL_interp 0.1 Any suggestions as how I can lower my choke I tried cmd,updaterate at matching settings of 30/50/70/90 and went witht what I was recommended to @100
I also adjusted my GPU from the stock settings of 775MHz memory to 825MHz highest aetting is 850 and the GPU clock speed from 1000MHz now at 1100MHz max setting is 1200MHz is this OKAY if not what sould I set them to??? fromSorry this post was a huge wall of words but I didnt want to ask ?'s without having all my system specs and settings listed.
When playing my keyboard tells me I'm using about 38% of RAM ans CPU is using anywhere from 20-35% avg spikes higer sometimes
Any and all help will be appreciated even if you can only answer 1 or 2 things I will still appreciate it very much. PS I was away at war for the past 5yrs so please forgive my PC ignorance as whats available today was only a wet dream the last time I bought a PC or played any games. THANKS Chuck
Processor 7.3
Ram 7.5
Graphics 7.7
Gaming Graphics 7.7
Hard Disk Drive 5.9
