Hi all,
I'm trying to connect another computer to a wireless network, but unfortunately the signal has to go through about 4 supporting walls to get to me (and up a floor). So I only get a low signal which the adapter cannot connect to.
What is the best solution, get a better antenna, or hook up some sort of bridge (how would that be possible btw?)?
I'm using a Belkin b Router with Belkin b PCI card. Are routers of the b variety very much the same for range, or do they differ?
thanks very much.
thanks very much.
