Sign-in / Sign-up
Solved
Power Supply Suggestion
  • Power Supplies
  • Cases
  • Components
  • Product
Last response: in Components
April 13, 2012 1:58:11 AM
Hi,
I'm building a new PC and the case i'm using is the NZXT Phantom. Because it's a full tower case, i heard people saying that they have difficulty wiring their PC up because the cables of the PSU are too short to reach all the way across (behind) the case.
I wanted to know if anyone can suggest a good PSU that can go well with Phantom or any other full tower case. The GPU i'm using is the Radeon 7950 so i need at least a 500W PSU with 2 6pin connectors. I really dont intend on crossfiring to be honest but i will likely OC the card.
So far this is the PSU i have but i feels like overkill:
thanks i appreciate it
More about : power supply suggestion
a b ) Power supply
April 13, 2012 12:37:04 PM
IMO,modular unit hardly makes any difference.if you are good,you can do a good cable management with non modular unit :p
m
l
a c 87 ) Power supply
April 13, 2012 12:55:50 PM
The NZXT Phantom is 540mm tall. The cable that I would worry about in terms of routing behind the motherboard tray and reaching it's destination is the CPU (ATX12V/EPS12V 4pin/4+4pin/8pin) cable.
According to reviews the 4+4pin cable on the Corsair TX750M is 60cm long, I'm sure on one of Corsair's PDFs it is listed as 65cm.
The 4+4pin cable on the Rosewill Capstone 750W is 60cm long. The 550W version is also a good unit and $80 with a %15 off promo code.
60cm long on the PC Power & Cooling Silencer MK II 750W.
The two 8pin cables on the Seasonic M12II Bronze 620 are 55cm long, so the least suitable out of the units suggested so far.
The hardwired 4+4pin connectors on the NZXT Hale82 units are 70cm long. ATM I can't think of any other units which have 'CPU cables' as long as that or even some other options with 'CPU cables' that reach 65cm.
m
l
a c 139 ) Power supply
April 13, 2012 1:02:29 PM
If you find a PSU that you like but are worried the CPU Aux power cable is too short you can always get an extender like this: 8" extension cable or 12" extension cable.
m
l
a c 144 ) Power supply
April 13, 2012 2:06:15 PM
Avoid Rosewill PSU's. A few are ok, but most are junk. And I am old; I never can remember which ones are which.
m
l
a b ) Power supply
April 13, 2012 2:13:47 PM
Capstone's are the good ones, actually really good.
m
l
Best solution
a b ) Power supply
April 13, 2012 3:19:51 PM
Yes, 750 W is overKill.
1) With a 7950, or a 7970, your Powere consumption under Load will be less than 350 Watts.
Ref: http://www.anandtech.com/show/5476/amd-radeon-7950-revi...
2) With a 750 W PSU idle power will probably put you below the 20% of PSU. Myself I prefer a Idle ratio of 20% and a Max load of <80%.
My Choice would be the Corsair TX650W. Still a litle overkill, but This would also handle Xfired 7950's in the slight chance you do decide to add a 2nd card.
$80 after 10$ MIR: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Note: for corsair do not opt for the CX, only get the CS or better yet the TX models.
a b ) Power supply
April 13, 2012 3:55:42 PM
^agree with RetiredChief here.
m
l
April 13, 2012 4:34:44 PM
Thank you for all the greaat posts guys. I haven't read them all but I will when I get back from work.
m
l
April 13, 2012 11:02:42 PM
i read throught them all great suggestions.
is there a way to find out how long the cables are? im looking at newegg and i cant seem to find out.
I would really like a modular/semimodular unit...
m
l
a b ) Power supply
April 14, 2012 8:49:09 AM
You should go to the manufactures's website to check this.
m
l
April 14, 2012 12:07:28 PM
For the brand's which don't publish cable length information you have to look for reviews.
m
l
April 15, 2012 5:33:49 AM
hmmm...i would assume that would be important information...
i wonder why they dont publish it.
anyway thanks a bunch guys
m
l
April 30, 2012 12:44:19 AM
Best answer selected by clydefrog.
m
l
