Hi all,
I recently built a computer with the following components:
Gigabyte GAZ68XP-UD3P
Intel i5-2500K
Sapphire Radeon HD 6870
Corsair XMS3 8GB 1600 (2x4GB)
Crucial M4 128GB SSD
Seasonic X750W PSU
At first, I suffered from the dreaded Gigabyte Z68 "boot loop" problem but was eventually able to solve it on an out-of-case build. The system worked perfectly then. However, as I had ordered the case separately, I suffered the problem again after installing the motherboard and components inside the case. I had checked and tried everything (switching RAM, PSU, clearing CMOS, leaving battery out overnight, re-seating the processor, etc.) and nothing worked. Thus, I decided to return the motherboard and try my luck with a different one (as Gigabyte Z68s are supposedly well-known for having this problem..)
I replaced the Gigabyte Z68 motherboard with the Asrock P67 Extreme4 Gen3.
I built the system out-of-case again. Upon connecting and engaging power, both the CPU and GPU fans spin, the Dr. Debug LED on the board lights up with the code "00". However, nothing further happens. No video is output on the screen, and no beep codes are ever output.
Again, I tried switching RAMs around, clearing the CMOS (both with the switch on the back and with the jumper), and switching the PSU. I tried doing a bare-bones start (no GPU or no RAM or both), but the same thing happens. I am starting to think that the defect may be with my processor at this point. What can I do?
Intel i5-2500K
Seasonic X750W PSU
