Stick with Cooler Master Hyper 212 Evo or upgrade to Corsair H80
Hi everyone,
I'm debating as to whether or not I should updrade my CPU cooling device. I currently have a Hyper 212 Evo with two Noctua NP-12 (Push/Pull) I get decent temps. I don't think I've seen it go above 54C.
My question is, should I keep the Hyper 212 Evo? Or should I upgrade to Corsaid H80?
Thanks!
1 answer Last reply
More about stick cooler master hyper upgrade corsair
  1. what you already have is pretty ok--so why spend when you dont need to
    if you get an h80 (i have one) then make sure and put those noctua fans on it as the default corsair ones are
    pretty loud
Cooler Master Corsair Evo Components
