as popatim asks. how do you know the card works? if you get no signal message on the monitor then the monitors fine but the card is off. if you get a black screen and the monitor hasnt gone into standby it means a failed post again broken card.
so unless you have tried the card in another machine then i would assume the card is the problem. if you have tested it in another machine then i would look at the psu in the original machine...
