[Problem] Lorem ipsum
Message body in here
4 answers Last reply
More about first build part compatibility check
  1. All of those parts will work together, but the case probably doesn't offer sufficient cooling with only one 120mm fan- either get a more expensive case or buy two extra 120mm fans for the back and sides. I would suggest you buy a slightly better case (make sure any case you buy has room for the length of the HD6950, most mid towers should)...
    Are you sure you don't want to overclock? If offers a lot of extra performance, although you would need to buy the 'k' CPU and an aftermarket cooler.
    Still, all those parts you've selected will work together, although the case is a bit dodgy :D
  2. Would you have any specific suggestions for a case?
    I'm not that confident in my computer knowledge to overclock, too afraid something might go wrong
    That case has been deactivated - looks like Newegg is discontinuing it.
    For the price - if you want to stick with Cooler Master - the HAF 912 would be a far better choice for the money, or maybe try something like the Antec 300, or - I'm not a particular fan of this brand but a lot of people seem to like them - the Rosewill Challenger.
    Everything will work for the most part but there's a couple of things I'd recommend over what you've chosen:
    PSU: Corsair TX650 V2
    Motherboard: Asrock Z68 Extreme 3 Gen 3 - *OR* - Gigabyte Z68XP-UD3H
    RAM: Corsair Vengance - Low Profile Version
    I'd also recommend getting a good fan even if you don't overclock - it will dramatically reduce system temperatures and help prolong the life of your system. The Cooler Master Hyper 212 is a good solid, inexpensive choice.
  4. Message body
Cooler Master Product Build Homebuilt Systems
