G
Guest
Guest
after a format... I downloaded the newest drivers for both my video, and sound cards... video installed fine... everything is working perfectly, my sound drivers will not install...
system:
82810E mobo, with onboard sound and video, both disabled...
PIII667E...
192 megs PC133 SdRAM
V3 3000 PCI...
Sound Blaster Live! Platinum 5.1 with Live! DRIVE IR... connected to Cambridge Soundworks FPS 2000 digital speakerset...
onboard hard drive controller with a single 15.1 gig IDE...
Logitech wheelman optical connected to USB port...
56k generic winmodem...
4 PCI slots:
top to bottom:
1:Sound card
2:Video card
3:empty
4CI modem
If anything else is needed then just ask... I've reinstalled rebooted redownloaded so many time I've lost count... I've tried switching the sound card to the 3rd slot... first slot has the memory by it... so the video card is in the way of the first slot... which means to have 192 megs of RAM I had to put a 64 meg, and a 128 meg dimm in there... I've disconnected the Live! DRIVE, and reconnected it... The gameport works, I've installed UT just to find out... and it works in UT... it's as if windows can't detect the actual soundcard, it keeps detecting a PCI multimedia audio device, but I can't find the correct drivers for it...
If any additional info is needed... just post... and I'll get back to you...
or you can ICQ me at 92591279...
system:
PIII667E...
V3 3000 PCI...
4 PCI slots:
top to bottom:
1:Sound card
2:Video card
3:empty
4CI modem
