Will this RAM work on b75 motherboard?
I am planning to buy this motherboard:
Asus P8B75-M LX PLUS Intel B75 SK1155
And i was planning to buy this RAM
G.Skill Sniper DDR3 2x4GB 1333MHz CAS9 1.5v Low Voltage
But in the RAM specifications doesnt mention the B75 motherboards, so the question is if it works on B75 motherboards? (just to make sure)
And if it doesnt work, why?
Thank you
3 answers Last reply
More about will work motherboard
  1. It'll work, but you really should buy a faster ram (1600 is the fastest that motherboard will take without over clocking). MB will come with a set of instructions which are downloadable at the ASUS site. There will be a list of compatible ram in those instructions. Make sure yours is on it.
  2. The CPU that i will buy (Pentium G2020) only supports 1333MHz so even if i buy faster RAM the motherboard will underclock it to 1333MHz, so no point to buy faster RAM there, only if i decide to buy a new better CPU :x
  3. Got it. Sounds like your on top of this. Happy building.
    EDIT: but if you ever want to upgrade the processor to an i3 or an i5, the speedier ram would help and its $5 bucks less...
Memory RAM Motherboards Product
