Pc only starts while removing CMOS battery
  • Power Supplies
  • Battery
  • CMOS
  • Components
Last response: in Components
April 14, 2012 8:42:36 AM
Hello,
Whenever I try to start the pc, it doesn't start
so i replaced the CMOS battery ...
after replacing cmos battery it starts first time without problem but when i shutt down the pc problem arise again and it didn't start so i removed the battery and then it started automatically .
please help me .. tell me what is the problem ??
More about : starts removing cmos battery
April 14, 2012 11:07:40 AM
Hi,
just buy a new battery and see if it does the trick. Many motherboards won't boot once the voltage of the RTC battery has gone below a certain voltage (normally somewhere between 2.8 and 2.9V) but *do* actually start without any battery...
m
l
a b ) Power supply
April 14, 2012 12:04:22 PM
Hi
do you mean Windows does not get to desktop and crashes or freezes ?
or
PC never gets as far as booting from hard disk
If you get to desktop is clock date time correct ?
(if not reset to correct date time)
corrupt cmos clock settings [nonsense date/time] can stop Windows loading
Have you cleared cmos [jumper]
or re-loaded bios defaults (in bios)
after changing battery
[clear cmos jumper left on clear pins will cause problems]
regards
Mike Barnes
m
l
April 22, 2012 1:50:06 PM
Thanks ... i replaced the battery and my problem solved !!
m
l
