Solved
Help with double gpus
Hy everyone;
I am building a HTPC and I want to buy and install at the same time a 590 and a 430 from nvidia;
The thing is I would like to choose which card to use when I turn on the PC so that when I am using the pc just for internet or movies or old games I want to use the 430 so to save power and lower the temps inside the case;
But when I want to play latest games with no compromises I would then need to use the 590;
What can I do? I do not like Lucid virtu of the z98 chipset;
Does the nvidia driver allow something like that?
Thanks a lot for your help!
Regards
3 answers Last reply Best Answer
More about help double gpus
  1. Best answer
    No, you cant run 2 graphics cards and switch between them through software.
    You have to either manually switch the cards
    Or buy 2 motherboards (including the whole rigs) and get a display switcher.
    In my opinion the Lucid virtu is the way to go, unless you want to have 2 different systems.
  2. I don't think that is possible.
  3. Best answer selected by italian_madness.
Graphics Cards Graphics
