"Dead" Motherboard - Power Switch Pin
- SolvedNeed help finding the power switch pins on my motherboard Forum
- Motherboard power switch pins having issues? Forum
- Is there an adaptor to connect standard PC power switch to ASUS P5N-D motherboard pins? Forum
- SolvedSwitch Dead | Possibly from wrong power supply cord used? Forum
- PC totaly dead, coupld it be power switch. Forum
- SolvedDead Power Switch? Forum
- 2 pin wire for power switch? Forum
- Will the power switch work to PSU even with a dead mobo Forum
- SolvedPower supply only has 8 pin CPU cable, but the motherboard only has a 4 pin socket? Forum
- SolvedI don't know if my motherboard has the required power connections for a 780 ti 6pin and 8 pin Forum
- SolvedDead Motherboard or Power Supply Forum
- Solved20 Pin Power Supply to 24 Pin Motherboard Forum
- SolvedPower PC on without motherboard power switch? Forum
- SolvedPower Switch Motherboard connection Forum
- SolvedAV3I motherboard power switch Forum
- SolvedUsing a Graphics Card with 20 pin Power to 24 pin Motherboard Forum
- SolvedPower supply dead or motherboard? Forum
- Solvedcan i use 4 pins of a 8 pin cpu power connector (ATX motherboard is 8 pin connector power supply is 4) Forum
- Solved4pin CPU power supply with 8pin motherboard? Forum
- SolvedCan't turn computer on, motherboard light on and power switch light... Forum
- More resources
Read discussions in other Motherboards categories
). Powered up the computer, everything seems fine, power it down, try to power it on again and nothing happens.
