D
^ Good catch!
That Corsair Vengance is the worst RAM in the world to use with an aftermarket cooler and I'm not sure whay they still make it. It gets in the way of even a small aftermarket cooler. Get the low profile version.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
DDR 3 runs so cool the heatspreaders are just for show anyway. Any GSkill Ripjaws X or Z will fit under your cooler as well. If you turn the fan it can affect performance.
D
Deleted member 217926
Guest
You should have no problems with the Antec 1100 and the DH 14. You may run into clearance issues with the ( optional ) side mounted fan but it can be quickly fixed with a Dremal tool and cutting a small notch out of the side of the fan. At least that's how I made my side fan fit in my Antec 1200 with my Scythe Mugen 2.
D
Guest
^ Good catch!
D
Guest
Not at all. The heatspreaders on DDR3 are just for show. It runs very cool even without any heatspreaders.
kickerconspiracy
Are there any fans out there that'll fit on the side with this set up as I've got a DH14 and am thinking of getting this case.
