Hi Board
I'd love some help deciding the best way to go for a new system. Details below:
Approximate Purchase Date: As soon as possible
Budget Range: up to GB£250
System Usage from Most to Least Important: NAS, Web Server for development purposes
Parts Not Required: keyboard, mouse, monitor, speakers, optical drive, discrete graphics
OS: Something like FreeNAS. Suggestions & recommendations welcomed
Case: Room for 2 x 3.5" HDDs eg ThermalTake Element Q, CFI-A9849
Preferred Website(s) for Parts: UK supplier of SFF systems & components eg scan.co.uk or mini-itx.com
Country: United Kingdom
Additional Comments: Ideally a fanless system but definitely a quiet one
Looking to replace my aging Synology Disk Station DS207+ NAS box. It does the job as far as storage & back-up are concerned but can no longer handle the
latest version of Wordpress that I use for developing web sites.
The system will be used for file storage & back-up; remote file access; web server for local development. It will not need to act as any form of home
theatre PC.
I could buy a new Disk Station but I think I can get a good system for less than the cost of a new Synology box. Also I'm quite keen to get my hands dirty
setting up whatever OS I decide to use.
I'm looking for suggestions & recommendations as to the most economical way of acquiring this system. Should I buy an off-the-peg system such as those from Shuttle, Zotac or Asus and use USB attached HDDs for big storage? Or should I build from scratch using a mini-ITX board with processor along with an appropriately sized case?
I would also like suggestions & recommendations as to the best OS to use for my purposes. Is FreeNAS the way to go or has anybody had good experiences with something else, Ubuntu Server for example.
Looking forward to hearing from the board.
Cheers
Jonny
theatre PC.
Cheers
Jonny
