This is my first build and I would love some advice for people that know what they’re doing.
Approximate Purchase Date: Sometime this month.
Budget Range: ~1200
System Usage from Most to Least Important: Gaming, work
Preferred Website(s) for Parts: newegg.com, tigerdirect.com, amazon.com
Country: US
Parts Preferences: Intel processor
Overclocking: Maybe
My build:
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
Western Digital Caviar Blue WD3200AAKS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
MSI N560GTX-Ti Twin Frozr II 2GD5/OC GeForce GTX 560 Ti (Fermi) 2GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127608
OCZ ModXStream Pro 600W Modular High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
GIGABYTE GA-Z68M-D2H LGA 1155 Intel Z68 HDMI SATA 6Gb/s Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128523
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
OCZ Agility 3 AGT3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227726
Looking forward to seeing your advice.
Budget Range: ~1200
Country: US
Overclocking: Maybe
My build:
