Advice on Intel i5 2500k system - $1500 (my first build!)
Hello! I want to do my very first PC build and am looking for advice, suggestions, corrections, thoughts, any knowledge.
I have decided to go with the i5 2500k as according to the benchmarks it seems it will work best for my use case. I filled out the form in the sticky below.
Here are my parts:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=22896647
Approximate Purchase Date: ASAP
Budget Range: $1500
System Usage from Most to Least Important: Photoshop, Illustrator, Flash (all CS4), Sony Vegas (minimal use), DVD ripping, video converting, MKV playback, HD video streaming/playback, and some gaming (I don't care if it runs demanding games crazy good, just needs to run all games good.)
Parts Not Required: keyboard, mouse, speakers, OS (Win 7 Pro, 64-bit)
Preferred Website(s) for Parts: newegg.com
Country: I'm in the USA
Parts Preferences: Just want to use the Intel i5 2500k. Flexible on the rest.
Overclocking: No
SLI or Crossfire: Maybe in the future, but I'm most concerned with video and graphics editing performance, rather than games
Monitor Resolution: will be buying a monitor, probably 20" or so at 1920x1080
Additional Comments:
I am aiming for a system that meets my current needs and is as much future-proof as I can get for $1500. I certainly wouldn't mind saving money if you noticed somewhere I could cut back.
I wanted a mobo that supports 32GB RAM even though I can't afford it 4x8GB sticks right now. Maybe I am wrong on this, but I think that is a good idea?
I am going to use the SSD for OS (Win 7 Pro) and apps install. I just did a fresh, bare-bones install of my current system with all apps and it's at 45GB. I looked at 60gb SSDs, but I am worried that is not enough cushion both now and going forward with more and bigger apps or future OSes.
I would have the 2 mechanical HDDs set to RAID 1.
Really appreciate any feedback. I have never built from scratch before and this will be my most expensive PC ever, so I want to do it right! Thanks!
5 answers Last reply
More about advice intel 2500k system 1500 build
  1. CS4 is only a 32 bit program from memory so you are unlikely to see much benefit from more than about 8 gig of RAM till you upgrade to 5 or 5.5 .
    2500k
    Z68 mb
    2 x4 gig of 1600 MHz RAM running at 1.5 volt or less
    400 watt psu
    Use the onboard video , or buy a budget level nVidia and used the lucidlogix drivers
    http://www.lucidlogix.com/product-virtu.html
  2. if you use alot of Photoshop, Illustrator, Flash i would spend money on your monitor. get a ips-pannel better Color Accuracy And Gamut. i realy like the Dell UltraSharp U2412M http://www.newegg.com/Product/Product.aspx?Item=N82E16824260047 it is only a e-ips pannel.
    if you have time to read this 24" LCD Round-Up: Acer S242HL, Dell U2412M, And Samsung T24A550 http://www.tomshardware.com/reviews/s242hl-bid-u2412m-t24a550,3016.html
    this is way more the you would need but under budget
    COOLER MASTER HAF Mid Tower $59.99
    ASRock Z68 Extreme3 Gen3 LGA1155 $124.99
    XIGMATEK Gaia cpu cooler $29.99 probably do not need this
    GIGABYTE Radeon HD 6950 1GB $239.99
    XFX Core Edition PRO850W $119.99 if you want to crossfire later other wise get a 600w
    Intel Core i5-2500 $219.99
    Crucial M4 CT064M4SSD2 2.5" 64GB SATA III 109.99
    G.SKILL Ripjaws X 8GB DDR31600 $43.99
    Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive 124.99
    Dell UltraSharp U2412M 359.99 you can get is cheaper from dell i think
    prices off newegg.com
    i do not know about optical drives that much so i did not put one on the build sorry
    i think a good ips-pannel would make you more happy then a fast rig but you can have both for 1500$
    Dell UltraSharp U2412M 349.99
    prices off newegg
    The IPS panel LCD is an excellent idea .
    But after that your suggestions are bad
    A $240 GAMING graphics card to edit video and photoshop is nuts . An 850 watt psu could run TWO of the unneeded graphics card let alone the one he does not have any use for .
    The HAF is a nice case but not appropriate to quiet office use
  4. like i said way more then you will need it was easy to cut and pasta my wish list from newegg yes much more of a gaming rig then he will need. it did not seem like a workstation i would never spend 1500$ on a work comp. on-board video probably be best for a workstation even though i have had bad luck with on board video
  5. Thanks for all the info and opinions!
    I cut back on the hard drives and went with 4x4GB RAM and saved some cash for now. Really wish I would have had the foresight to buy hard drives 3 months ago when they were 1/3 of the price! :??:
    Although I'm concerned right now with graphics and video work, I was trying to future proof as much as I could. I still went with the fancy $200 mobo because of the potential of dual video cards.
    Basically, I want this machine to last me at least 7 years. Then I figure I can recycle some parts into more basic builds--maybe a HTPC or fileserver or something.
    I appreciate the links to read up on the monitors. Never heard anything IPS panels before. A monitor is my next big purchase (in a few months), so I am going to begin my research for that now.
    Thank you again for all the help!
Build Intel i5 Systems Product
