Solved
GTX 560 SLI i7-2600k power needs?
I'm doing a build with the above components, and I would like to know of a well priced yet great performing PSU. Is it possible to run this set up with 750 or 700? The exact cards are the ASUS GTX 560 DCUII OC.
I am already spending $855 on the build, not including taxes, and all that is left is the PSU. I can only spend up to $1000 in total.
Thanks for the help!
2 answers Last reply Best Answer
More about 2600k power needs
  1. Best answer
    OCZ 750watts with all the connectors you need on a great deal after MIR http://www.newegg.com/Product/Product.aspx?Item=N82E16817341049
  2. Best answer selected by Unknownxxvii.
Power Supplies Gtx Intel i7 Build Components Product
