Closed Solved
Radeon 6950 4 Monitors? Need Help!
Hi guys, I'm having trouble with Radeon 6950 (MSI) single card.
Trying to do 4 monitors set up but only recognize 3 monitors... I am using active display monitor port.
Also its says on the box "support for up to four displays".... but is this have to be crossfire?
4 answers Last reply Best Answer
More about radeon 6950 monitors help
  1. Best answer
    It might have to be... It has 2 DVI, an HDMI, and 2 DPs, right?
    If you want that many monitors, ASUS cards are probably better.
    Hi thanks for reply.
    I just changed one of my DVI cable and now it is working properly!
    Thank you
  3. Best answer selected by inspire05.
  4. This topic has been closed by Maziar
Radeon Monitors Graphics
