Will this Gateway run Skyrim? Please help!
Last response: in Systems
Gateway FX6860-UR20P Desktop PC - Intel Core i7-2600 3.4GHz, 8GB DDR3, 1.5TB HDD, ATI Radeon HD 6750, DVDRW, Windows 7 Home Premium 64-bit $899.00
Really need help finding a pre-built pc to run Skyrim for my teenaged son...will this play it and, if so, what settings? I would love to build my own, but just can't right now. So any suggestions or links to pre-builts would be soooo appreciated!!! My budget is $900. or less and we do not need monitors, or any other accessories. Thanks so much!
More about : gateway run skyrim
Thanks for the replies...I would love to build my own, but just can't right now, so I am just going to buy a pre-built and hopefully upgrade the graphics later on if need be. I am planning on buying a new monitor a couple of months down the road. Will one be better than another for running mostly high graphic games? I am looking at getting an led monitor.
Hi, That PC will run Skyrim if you can't put your own system together, I use the HD5750 (same as the HD6750) and play on high Detail, 1920x1200. And my CPU is weaker, a its a AMD 720BE @3.4.
Ask the community
