mrclownface
633
5
19,065
hi there,i need help with graphics driver problem,i just installed a new gainward gtx 560ti golden sample,i installed the nvidia driver software,but i seem to have a problem with a AMD catalyst control centre issue,when i restart my pc i get this message come on the screen..
.the catalyst control centre is not supported by the driver version
of your enabled graphics adapter,please update your AMD graphics
driver,or enable your AMD adapter using the displyays manager
can anyone please help me urgently with this issue,any help is much appreciated..thanks in advance
mrclownface
633
5
19,065
You need to download driversweeper from here: http://www.guru3d.com/category/driversweeper/
Then get rid of all Nvidia and AMD drivers then reinstall Nvidia 285.68 ;)
i tried to download it but found this notice on the link page...
Attention - Guru3D Driver Sweeper has been discontinued
as such you will not find any download links here any longer.
im not sure what to do now to fix this issue,thank you for the fast reply
mrclownface
633
5
19,065
This site is trustworthy and has it up: http://www.softpedia.com/get/Security/Secure-cleaning/Driver-Sweeper.shtml
hey thanks,i have installed it,and found the following...
AMD-DISPLAY
NVIDIA-CHIPSET
NVIDIA-DISPLAY
NVIDIA-PHYSX
SHOULD I REMOVE ALL OF THESE AND DOWNLOAD AND INSTALL Nvidia 285.68 ;)DRIVER...YOUR HELP IS MUCH APPRECIATED
