M mrhappy77805 Honorable Feb 24, 2013 1 0 10,510 Feb 24, 2013 #1 where is cmos battery in toshiba satellite p755d s5386
TenPc Honorable Jul 11, 2012 2,471 1 11,960 Feb 24, 2013 #2 You'd probably have to dismantle the whole laptop to find it, I doubt that Toshiba would put it in a conspicuous spot. Check out the following links that might be helpful - http://www.tomshardware.com/forum/247842-30-replace-cmos-battery-toshiba-satellite http://www.ehow.com/how_5136793_replace-cmos-toshiba-satellite-laptop.html Make sure you don't thread the screws otherwise you'll never get them out. Also, buy a new cmos battery before you start the procedure. Upvote 0 Downvote
J jarotech Dignified Oct 13, 2012 3,927 2 16,960 Feb 24, 2013 #3 You may find this link useful : http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P755-P755D-P750-P750D/disassemble-P755-1.htm Upvote 0 Downvote
