Help with Multi OS Gaming Rig
"Approximate Purchase Date:03/03/2012
Budget Range:e.g.: 1500-2000)Before / After Rebates
System Usage from Most to Least Important:Gaming,School,Powerhouse Multidmedia,Multi Functionality
Parts Not Required:window7, Lion OSX, Monitor, Keyboard
Preferred Website(s) for Parts:newegg.com, FrozenCPU.com
Country: USA we need to know where these parts are being assembled
Parts Preferences:by brand or type ASUS, ASUS, ASUS
Overclocking: Yes
SLI or Crossfire: Yes
Monitor Resolution:1920X1200
Additional Comments:I am stuck with the case and the positive pressure that it offers, and I am not buying it for fan power
QTY PRODUCT PRICE FEATURES
1 Antec Lanboy air Blue/Black / Red Steel / Plastic ATX Mid Tower Computer Modular Case $159.99 Works of positive air pressure, comes in 3 colors, Modular http://www.newegg.com/Product/Product.aspx?Item=N82E16811129093
1 ASUS Crosshair V Formula AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard with 3-Way SLI/CrossFireX Support and UEFI BIOS $229.99 Amazing look!, Seriously ready for OC'ing, http://www.newegg.com/Product/Product.aspx?Item=N82E16813131735
1 C.P.U. - AMD FX-8150 Zambezi 3.6GHz Socket AM3+ 125W Eight-Core Desktop Processor FD8150FRGUBOX $269.99 8 Cores! 8 CORES!! 8 CORES!!! http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
2 G.P.U X2 - ASUS EAH6870 DC/2DI2S/1GD5 Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity $379.98 What can I say… this is an awesome video card to run in crossfire. 1 Gb tied together 418&Tpk=asus radeon 687http:/www.newegg.com/Product/Product.aspx?Item=N82E16814121418&Tpk=asus%20radeon%206870
1 P.S.U. - CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply $149.99 Well… It has a blue sticker! http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010&Tpk=corsair%20hx750
2 Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive $249.98 Still reasearching the best HDD not really an issue here.
1 Memory - CORSAIR DOMINATOR 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMP16GX3M4X1866C9 $159.99 There Blue! http://www.newegg.com/Product/Product.aspx?Item=N82E16820233228
COOLING EQUIPMENT
1 Black Ice GT Stealth 240 X-Flow Radiator - Blue $60.95 Again with the Blue! http://www.frozencpu.com/products/4084/ex-rad-85/Black_Ice_GT_Stealth_240_X-Flow_Radiator_-_Blue.html
1 Cooling System - Koolance RP-1005BK 1kW Series Reservoir & Pumps in 5.25" Bay - Black $237.99 What's up with this blue theme!!! Hahah, It has digi temp readout of the fluid, also more readouts of temps. http://www.frozencpu.com/products/14146/ex-res-302/Koolance_RP-1005BK_1kW_Series_Reservoir_and_Pumps_in_525_Bay_-_Black.html
1 Koolance CPU-370 Liquid Cooling Extreme CPU Block $87.99 Not anything special with this, just that it is part of there new line. I would like to research this more. http://www.frozencpu.com/products/12571/ex-blc-874/Koolance_CPU-370_Liquid_Cooling_Extreme_CPU_Block_-_No_Fittings_.html
1 Bitspower Galaxy Freezer DIMM4 RAM Liquid Cooling Block - Ice Blue (BP-WBDM4AC-IBL) $62.99 It's Blue http://www.frozencpu.com/products/13714/ex-blc-937/Bitspower_Galaxy_Freezer_DIMM4_RAM_Liquid_Cooling_Block_-_Ice_Blue_BP-WBDM4AC-IBL.html - blank
2 Heatkiller GPU-X³ 6870 ATI Radeon 6870 Reference Design Full Coverage Water Block (15007) $199.98 This is more of a want then a need, but I am considering size in the case I am not trying to cool everything. http://www.frozencpu.com/products/12897/ex-blc-894/Heatkiller_GPU-X_6870_ATI_Radeon_6870_Reference_Design_Full_Coverage_Water_Block_15007.html?tl=g30c309s1349
1 IandH Dead-Water Copper Sulfate Biocidal PC Coolant Additive $4.99
1 Koolance Liquid Coolant Bottle - Fluorescent Blue - 700cc (LIQ-702BU-B) $18.99
1 IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip $6.99
TOTALS $2,280.78
4 answers Last reply
More about help multi gaming
  1. Hello Yashua916;
    I see a few items in your list that I haven't previously seen on any Hackintosh builds.
    Have you checked for OSX drivers for all hardware?
  2. WR2 said:
    Hello Yashua916;
    I have looked around but It's my first hackintosh attempt and thats why I am here. Do you have somme suggestions of where I can look to check on my hardware?
  3. I'd work with some of the Hackintosh sites to see what others have had success with, or are recommending.
    You're going to find the 'hardware pool' is a lot shallower for OSX than for Win7.
  4. If I were to guess:
    ASUS Crosshair V Formula AM3+ AMD 990FX (and it's AMD FX-8150 Zambezi CPU) will be hardest to source OSX drivers.
    Only dual HD 6870s in a $2000 system? Looking at the rest of your build I'm thinking you're investing too much or your $$$ into the system cooling and not enough in your system performance parts.
New Build Systems Product
