Need help, building new pc
Last response: in Systems
Approximate Purchase Date: Within a week (January 5-10)
Budget Range: 1400-1600(Does not include graphics card)
System Usage from Most to Least Important: Gaming, watching blu ray movies, browsing the internet, some beginner programming, typing papers <-- :cry:
Parts Not Required: keyboard, mouse, speakers, I am waiting on the graphics card until the next generations comes out, monitor
Preferred Website(s) for Parts: amazon or newegg (I have amazon prime which gives free 2 day shipping on most items)
Country: USA
Parts Preferences: Intel and nvidia(processor and graphics card) mainly major brands
Overclocking: Maybe
SLI or Crossfire: in the future possibly
Monitor Resolution: 1920x1080
Additional Comments: 3d gaming in the future, reliabilty, future proof
Case:
Azza Hurrican 2000
Motherboard:
Asus P8Z68-V Pro/Gen3
Processor:
Intel Core i7-2600k
Cpu fan:
COOLER MASTER Hyper 212 EVO
or
ZALMAN CNPS9900MAX-B 135mm Long life bearing CPU Cooler Blue LED
Memory:
Corsair Vengeance Blue 16 GB DDR3 SDRAM Dual Channel Memory Kit
PSU:
Corsair CMPSU-950TX 950-Watt TX Series 80 Plus
GPU:
I am waiting for the new generation to come out from nvidia, If I need a gpu to be able to use my pc then let me know please, in the mean time I plan to type papers and read while waiting to play BF3, Skyrim, and Flight Sim
HDD:
I am waiting for the price to drop from the high prices from the flood
SSD:
Crucial 128 GB m4 2.5-Inch Solid State Drive SATA 6Gb/s
Optical Drive:
LG Electronics WH12LS39K M-Disc 12X Blu-Ray Disc Rewriter and HD DVD-ROM Drive
OS:
Windows 7 Professional SP1 64bit (Full) System Builder DVD 1 Pack
I will be using the SSD as my main storage and boot until HDD's drop back down. I will buy PowerDvd 11 for the software with the optical drive. Combing all the parts I have listed I come up with $1454. If I can stay on the lower in of 1400 then that would be great as I will eventually buy the graphics card and a pci wireless card.
So my questions are:
1. Do you see anything that woudn't be compatible with this build?
2. Can I do simple task on this comp without a gpu like surfing the web or typing a paper. I assuming I can because it has a built in dvi and hdmi port to the motherboard.
3. Anything you would change that would make a big improvement for a small price?
4. Anything unnecessary that could be changed for a decent price drop?
5. Cooler master or the Zaldan?
6. Any bottlenecks other than lack of graphics card?
7. Am I missing anything major as this is my first pc build?
Thanks for the help ahead of time!!!
More about : building
Awesome set of parts. Any single graphics card (and most dual) will be fine with Corsair 750w PSU -- could save you 50 bucks. I haven't used the Zalman but I'm a fan of the Hyper 212.
Sounds like you have money though!
This is a better cooler than the Zalman at ~$60:
NZXT Havik 140
Personally I would not go for the Hyper 212 Plus/Evo because its fan has a maximum speed of 2000RPM, which I would find too noisy. But if that doesn't bother you then it's a good choice.
Altho with either the Cooler Master or the NZXT Havik it would be a good idea to get RAM without tall heatspreaders, it would be a good idea anyway as tall heatspreaders on DDR3 RAM are unnecessary.
16GB is kind of overkill for a gaming build, 8GB for ~$50 seems like a significant saving to me.
If you are going for the top end next gen Nvidia card and really do want the option to add a second one then you probably will need a 950W PSU. If it is a more mid range card or you are really reluctant to add a second one then you should be getting a lower wattage, higher efficiency, modular unit.
Yes you will be able to use your build without a GPU.
Alright, after a little more research I've decided to go with the Zalman because it is a little more quiet and wont mess with my memory heatspreaders although those may not even be necessary.
Another question i have is for the os, do i need to buy the 200 dollar something version or is the oem the one i want for system building.
Any other input for any of the other parts would be great, may start ordering things tomorrow so i can hopefully get this built before I go off to school
First of all, any reason your buying the i7 over the i5-2500k? You could save yourself a bundle there with no loss of performance in gaming.....
With a Z68 motherboard, you do not need a GPU to use your PC, the motherboard comes with video outputs and will use the GPU built into the CPU chip.
RAM: 16GB is pointless unless your using applications you know for a fact will actually utilize it. Games will not make use of more than 3-4GB at MOST. 8GB RAM, 1600MHz, CL9 is the current sweet spot for price vs. performance and is still over-kill for all gaming builds.
Ask the community
