Need Advice for sub 1500 build
Approximate Purchase Date: Sometime this month
Budget Range: 1000-1500
System Usage from Most to Least Important: Gaming, videos, surfing web, programming
Parts Not Required: : keyboard, mouse, speakers, OS
Preferred Website(s) for Parts: newegg.ca, ncix.com, tigerdirect.ca, http://www.canadacomputers.com, newegg.ca
Country: Canada
Parts Preferences: Really want i7 2600k, SDD for windows, HDD for rest.
Overclocking: Yes
SLI or Crossfire: Yes
Monitor Resolution: 1920x1200
Additional Comments: Needs to be quiet
Thank You!
4 answers Last reply
More about need advice 1500 build
  1. MOBO : http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131792
    CPU : http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115070
    RAM : http://www.newegg.ca/Product/Product.aspx?Item=N82E16820178382
    GPU : http://www.newegg.ca/Product/Product.aspx?Item=N82E16814125401
    HDD : http://www.newegg.ca/Product/Product.aspx?Item=N82E16822152185
    SSD : http://www.newegg.ca/Product/Product.aspx?Item=N82E16820148528
    PSU : http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139029
    CASE : http://www.newegg.ca/Product/Product.aspx?Item=N82E16811352017
    CPU COOLER : http://www.newegg.ca/Product/Product.aspx?Item=N82E16835608018
    TOTAL : $1,465.41
    You have a mobo with posibilities to SLI , a power supply what can support SLI , cpu overclocked and everything you want to put on that PC.
    The case is quiet . The cpu cooler is verry quiet and one of the best.
    Its dificult to do an pc just from one site because on other site some parts can be with 20-30$ cheaper,and some parts are not available on other site. I used to compare newegg and canadacomputers
  2. I think you forgot the Monitor. But great build overall. its a win win.
  3. 2600k is not for gaming.2500k is similar for gamaing.
  4. If you are really into gaming you may not need i7 2600K, i5 2500K is sufficient Also does your build needs monitor if yes then I have already included it. Based on these here's a suggestion:
    CPU: $230- i5 2500K
    Cooler : $37- CoolerMaster Hyper 212 EVO(To provide good cooling during overclocking)
    SSD: $200- Crucial M4 128 GB (A SSD large enough to hold Windows on other programs and games)
    Case: $65- Xclio NightHawk
    HDD: $130- Seagate Barracuda 1TB
    Monitor: $210- Asus VS248H 24"
    GPU: $280- MSI Twin Frozr II Radeon 6950 2GB
    PSU: $120- PC Power & Cooling 760 Watt 80plus Silver
    RAM: $32- Patriot Signature 2X 4GB
    Motherboard: $134- Asrock Z68(Good motherboard , supports Crossfire, etc)
    Total(Excluding Rebates): 1437 USD
    Rebates: 20 USD
    That should help.
New Build Systems
