Yes No
Ads
4870 problems
Forum Graphics & Displays : Graphics Cards 4870 problems
Related Content
Can't find your answer?
Ask!
i have some artifacting problems with HD 4870 lately with some games (like battlestar galactica,lineage 2) but i dont have problem with other games like (MW 2,world of warcraft).It seems strange because MW 2 require better graphic card than lineage 2...i updated my motherboard BIOS drivers and graphic card drivers aswell.But i still have the same problems
my system:
intel core 2 quad Q9550 2ghz
gigabyte EP35 DS3L
4 gb ram DDR2 400mhz
Radeon HD 4870
power supply 650
Message edited by sarevok on 11-07-2011 at 10:57:22 PM
Reply to sarevok
Artifacting or screen tearing?
Reply to rolli59
- 0 +
artifacting only
Reply to sarevok
- 0 +
Then vsync would not help.
Reply to rolli59
- 0 +
Hmm, are you sure the card temps are fine?
Updating card's driver?
------------------------------ Core 2 Duo E6300 1.8 GHz (OC at 3.0 GHz) / Zigmatek HDT S1283 CPU Cooler / Gigabyte GA 965P-DS3 Motherboard / 2x1 GB DDR2 800 RAM / 2x160 GB Seagate HDDs / SilverStone ST50F 500W PSU / HIS IceQ 4 HD 4850 512 MB DDR3 / 17" LG Monitor
(Little Dinosaur)
Reply to wa1
- 0 +
well the graphic card temperature where around 85-90C and as far as i know the 4850 works around 80-85C so 5 celcium up i dont think that is a problem
Reply to sarevok
try and set the fan speed in the AMD drivers, i get worried when the card idles at 70+ C, so i changed the fan manually, i got mine set to 40% all the time, and dont battle with heat issues even under load.
The card mite be dying out due to excessive heat.
------------------------------ Intel Core 2 Quad Q8400 2.66 @ 3.6Ghz, ASUS P5QD Turbo Motherboard, 4Gb DDR2-800 Transcend RAM, XFX 4870 1Gb GDDR5,HAF912 Chassis, 700W Huntkey Power Supply, G5 Mouse, Gigabyte Aivia Keyboard, Samsung 23" LED Monitor, Looking at Roccat Kave 5.1
Reply to CoffeeDrinker
- 0 +
well during soem experiments i puted it work on 80-90% with temps aroune 80%
when the fan is not working the temperature rising around 80-85 degrees
so i always have it work around 40% to keep a good temperature around 70 degrees
Reply to sarevok
- 0 +
Reply to sarevok
if heat is not going down even when you set the fan, i think you mite need to clean out the heatsink and put new thermal paste. coz that could be reasoning to high temps.
- 0 +
that might be
i will soon gonna buy a new thermal paste to put it on GPU but when i play some games i have the fan working on 100% and sometimes i keep playing it for 1 hour without problem and sometimes it just stuck on the very first minute
Reply to sarevok
- 0 +
that might be
Reply to sarevok
- 0 +
well i will change my paste anyway, :)
Reply to sarevok
when all is done and dusted, post back here to let us know if it worked.
- 0 +
well the shops were closed for today :(
so i am gonna buy tommorow some paste
Reply to sarevok
- 0 +
well i think that i found the problem...There was a problem with stock clocks...something like fail overclock.I changed it clock and there was no problem.
i will change the paste anyway i bought 1 today.
Reply to sarevok
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > 4870 problems
There are 2024 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Will this video card work on my PC..
By looniam, 3 hours ago:
no need for power connections and your PSU is ok to go with it...
Best offers
Top experts
