Hi there!
I just joined up today (five minutes ago, actually!) and I want to ask this fine community about a build question I'm having a hard time figuring out.
I recently got my z77 extreme board from Newegg along with an I5 CPU and a Cooler Master fan.
I also got an Artic Silver Thermal Tube and correctly applied to both the CPU and The Fan. So no burning smell from the CPU!
Well, now here is the issue I'm having:
After installing the Mother board to my atx tower, complete with brass nobs under it, I went ahead and installed every piece of hardware carefully to the booklet.
Now when I start it up, the components turn on and stop a second later.
Now, before coming to you fine ladies and gentlemen, I tried to troubleshoot it myself, as with any decent tech junkie should do.
Here is a rundown of what I did:
1. Put on a anti-static wrist strap
2. Propped open the case on a wooden table
3. carefully put each component on an anti-static mat.
At this point, I started to breadboard each component with several restarts via the board's power button, everything was working fine until...
I noticed that when I used the Power supply's power connectors to power on the hard drive, the computer simply powers on and shuts off.
I figure: Is that what's causing the short?
So I wipe the hard drive after getting key files out (my documents, music etc.), I installed windows 8 again and everything is running great.
Then the computer goes out again.
So ladies and Gents, here is my dilemma.
What is causing the short? Is it the PSU?
I should also mention that everything was dusted out with a set of canned air...cans.
Here is my specs:
Z77 Extreme 4 Motherboard
Intel I5 CPU and Coolermaster CPU Hyper 212 Plus Treated with Artic Silver Thermal Compound.
(I read on the other tom's forums that it should be spread evenly around with a pea sized drop on each component.)
EVGA brand Nvidia GTX 560
One 8GB Vengeance stick of RAM
One Seagate 360 GB Hard Drive.
One Antec 750 Watt PSU.
Finally, One Multi-read/write DVD/Blueray Drive. I believe its 8x, but I'm not certain.
If anyone should wonder what my ATX case is, its a Rosewill Challenger.
I really hope you boys and girls could help me with my problem.
Thanks,
Rocksilver
Here is my specs:
Thanks,
Rocksilver
