Solved
Sound conflicts?
  • Motherboards
  • Components
Last response: in Components
April 18, 2012 5:47:29 PM
I have an Asus P4C800E deluxe motherboard and a Creative Labs Audigy X-Gamer. Upon formating and reinstalling Audigy noticed the onboard sound. I am using the Audigy card do I need to disable the onboard sound? Will it conflict with the sound card? I have no idea how to disable it.
More about : sound conflicts
Best solution
a b V Motherboard
April 18, 2012 6:07:39 PM
Hi :)
Yes you NEED to disable it in the BIOS....
All the best Brett :)
April 19, 2012 4:54:37 PM
Best answer selected by Heathcliff.
m
l
April 19, 2012 5:02:04 PM
Brett928S2 said:
Hi :)
Thanks Brett :bounce:  that helped a lot I hadn't formatted in ages and wasn't sure I would just like to comment Asus has very good motherboards and the best service from my past experience with them it was pretty straight forward where it was in the bios :wahoo:
m
l
