After searching a lot I found this on net .. and finally choose xonar Dx
_________________________________________________________________
Content from google :
first of all, congrats to op for buying a nice speaker system! And where are the pics dude??
I was expecting loads of pics in the thread!
You can search for wall mount brackets online or you should be able to find the appropriate hardware at any electronics store.
Now, I'll like to share something regarding Z906's connectivity:
First of all, go for a good quality soundcard. I'd recommend, Asus xonar.
Make sure, you go with one, which suits your needs. There are models which sports onboard DD and DTS (D2X) decoders.
I've Xonar DX. Its good and drives my Z5500 nuts!
For Z906, i'll suggest DX too! As Z906 packs inbuilt DD/DTS decoder, you can bypass the onboard sound processing by connecting your system with SPDIF.
Remember, SPDIF, both coaxial and optical (toslink) only supports 2-channel PCM audio, 5.1 Dolby and 5.1 DTS. Generally, DVD's and BLurays contains
5.1 Dolby and DTS, so the information is just sent to Z906. However, video games and windows application does not use Dolby or DTS. they mainly use 5.1 PCM.
Since SPDIF cannot bring 6-channel PCM, you only receive stereo.
However, there are stuff called Dolby Digital Live and DTS Connect. These stuff convert the 6-channel PCM into 5.1 Dolby and DTS respectively so you can enjoy
5.1 sound from your games through SPDIF in Z906. These DDL and DTSC is an exclusive feature in X-Fi cards.
Another thing i experienced with Z5500 and Z906 systems was that both perform excellently when connected in 6 channel direct analogue mode. Do remember,
that if you are connecting your system digitally, then you're bypassing your onboard/soundcard's processing abilities. Not recommended, if you've sound cards like Xonar or X-Fi!
They easily surpass the built in Z906/Z5500's processor quality!
Okay, enough with "pravachans"!
See, you need to be more discrete about how you like sound to be heard. These are THX certified speaker systems.
Play out with different settings and try to achieve the best spatial arrangements for the satellites. Find a good spot to place your woofer.
Do remember, if placed properly, Z906 will definitely give you the best and immerse movies and gaming experience. I did the same with mine Z5500, and trust me nothing beats it!
Take your time and let Z906 brings you the whole new meaning of sound quality to your experience! Congrats once again pal. Post a detailed review w/t pics when you're done with setup and everything.
http://www.asus.com/Multimedia/Audio_Cards/Xonar_DX/#overview
_________________________________________________________________________
After purchasing the card :
If you buy the Xonar DX then all you need to do is use the 3.5mm to optical adaptor that comes with the sound card, then connect the optical cable to your speakers.
Just set the speaker option in the asus control panel to 2 and select spdif out to dolby digital live, then click the option that says dolby prologic 2x, anything thats in real 5.1 will be untouched,
anything in 2 channel e.g. music will be upmixed to 5.1 then encoded to dolby digital.
That's all you need to do mate.
__________________________________________________________________________
Purchase this cable :
Digital Optical Audio Toslink
