Would *really* appreciate some assistance/advice.
I'm buying a few pieces at a time, so far all I've gotten are the case and power supply. I realize I should have made this thread before buying anything, but better late than never.
My main concern so far is whether I screwed up by getting a 750w power supply rather than 850w.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Those are the items.
I'd love some input on whether these were good choices, and my concern about the wattage comes from thinking that I may do my first ever dual video card setup. I have an Asus G73 laptop that I use currently, and that will be what I continue to take with me when I go out on deployments on my submarine, but this will be my real powerhouse back home I'm hoping. I want to do it up right. I chose these 2 items because they were rated highly on newegg.
Will a 750w be enough to run 2 Nvidia cards? I have an ATI card in the laptop and wanted to give Nvidia another try. I like to alternate.
I'd also love any advice on motherboard in particular, but also processor, everything really. I know this is very vague and a lot to ask. The only thoughts I can provide for guidance are that I am doing a few pieces at a time so I can afford to spend more on each, but still don't want to get *totally* ridiculous on price. If I can keep the whole system under $2000 that would be cool, but if it's not possible I'll deal with it.
I play a lot of computer games, I would ideally like to be able to hook up to both my 27" Dell monitor and my 40" Samsung LED TV (which I currently use for most gaming, lot of Skyrim) but of course 1920x1200 and 1920x1080 don't exactly play well together when I try to clone the image so I guess I need something that can spit out the image at 2 resolutions, maybe? I'm not saying I need to see a game on both monitors at once... just would like to be able to use either interchangeably.
I'm going to do a solid state HD at least for Windows, may not be practical given my space requirements to do it for anything more than that. I guess I'll need to buy another copy of Windows 7 64bit too.
But yea, I've been at this PC gaming thing since 1989 but I've always sort of skirted around the edge of really truly knowing that much, I've put together a few systems but usually have had help and guidance. I have not been keeping up with video cards, etc for some time now. Hence my asking for help. I know I could just go research it but I like interacting with others.
Thanks a ton if you respond.
