Hey everyone im building this new pc and I just need to know if all the components will work with each other.Here are the specs:
ASUS GTX680
Intel® Core™ i7-2600K Processor
(8M Cache, 3.40 GHz)
Corsair 16GB (4 x 4GB) PC3-16000 2000MHz DDR3 RAM - 9-10-9-27 - Dominator GT
ASUS Xonar D2/PM - 7.1 Channel, 24-bit/192kHz, 118dB SNR, Dolby, DTS - PCI
ASRock Z68 EXTREME4 Gen3 MB, Intel Z68, 4x DDR3, D-SUB, DVI-D, HDMI, DP, 7.1CH, GbLAN, PCIe 3.0, SATA3, USB3.0, ATX
Western Digital 2000GB (2TB) Intellipower SATA-III 6Gbps HDD w. 64MB Cache (WD20EARX) Caviar Green
ASUS BC-12B1LT Internal Blu-Ray Combo Drive
ATX Storm Trooper Case
ACER S273HL 27" FULL HD WIDESCREEN LED MONITOR
Antec Kuhler H2O 920 CPU Cooler - Intel LGA1366/1155/1156/775, AMD AM3 /AM2 /AM3/AM2, 120mm Fan, 700-2400rpm, 110.0CFM, 27.4dBA
Antec 750W TruePower ATX 12V v2.3, EPS 12V v2.91, 120mm Fan, Hybrid Cable Management, 80 PLUS Certified, SLI Ready
ASUS GTX680
