New PC power on
Last response: in Systems
Just finished building my 1st PC...
When I 1st powered it on after a few seconds it restarted (fan's span down and then began spinning again). It then was ok, so went into the bios, reset the PC and it happened again. I've done a few more boots to bios - some times it will power on and off, sometimes not!
I did a test boot outside the case and it didn't do this at all!
Is this normal? If not what should I be doing?
Spec:
i5-2500k
Asus Z68 V-PRO Gen 3
8GB Corsair Vengance DDR3
Asus GTX 560ti
Corsair 850HX PSU
M4 128GB SSD
WD 1TB Caviar Black
2 x Sony DVD drives
...in an Antec 902 v3
More about : power
esting outside the case - sat on mobo box. Behaves exactly as it should, powered on & used the onboard reset button a number of times.
When I exited saving changes from the BIOS though, it restarted 3 times before posting! Help please?
Ask the community
