OK so I got a new gaming rig a month or 2 ago. It runs good, I decided to O\c it and before I did I downloaded speedfan and a few other monitering programs. I went into my bios that has O\c genie II on it, And I used the auto o\c settings, It worked good, temps wernt too high for a stock cooler, but it did get up there after a little bit of gaming (mw2, wow, skryim) it got into the upper 50c range, so untill I get my liquid cooler I turned it back to the standard settings. Now at idle 31-36c, I know thats not terriable but as soon as I open any program it jumps to 45ish and keeps climbing up to 55ish, then I close out the program. Even with the runescape client it jumps that high. I dont know if thats normal or not.
Specs:
MSI 970A-G45 Motherboard
AMD FX-6100 Black Edition CPU
Nivida Geforce GTS 450
8 Gigs of Corsair Vengance Ram
250 & a 320gig Sata HDD
Also I read another thread(I dnt remember where but) that said when the O\Ced then went back to stock settings it didnt change the voltage and that was why it was running hot. My voltage goes up and down at idle, anywhere from 0.952V and 1.4somthing. Im not sure if thats stock or not though.
Specs:
