Solved
Making new power supplies with SATA connectors work with IDE drives
  • Power Supplies
  • SATA
  • Hard Drives
  • Components
Last response: in Components
April 19, 2012 9:46:12 PM
I have an old computer with two IDE hard drives. The power supply has started making a very loud noise as if the fan is touching something so I want to replace it.
The new power supplies have SATA connectors but I have IDE drives. Would it be possible to make any new power supply work my old IDE drives?
Thank you!
More about : making power supplies sata connectors work ide drives
Best solution
a c 1217 ) Power supply
April 19, 2012 10:34:29 PM
Your IDE (a.k.a. PATA) drives should be using the standard 4-pin Molex Peripheral power connectors that are still provided on any current power supply unit on the market that you buy.
April 21, 2012 11:52:25 AM
Thank you for your response.
m
l
April 22, 2012 10:49:47 AM
Best answer selected by jss2020.
m
l
