Approximate Purchase Date: a month 2 1/2 max
Budget Range: 1000$ to 1200$ Before rebates
System Usage from Most to Least Important: gaming, surfing the internet encodeing ps2 emulation
Parts Not Required: keyboard, mouse, monitor, speakers, OS
Preferred Website(s) for Parts: newegg.com
Country:usa
Parts Preferences: lga2011 for upgrade path and cpu choice lator
Overclocking: Yes Maybe
SLI or Crossfire: Maybe
Monitor Resolution: 720p can do 1080i but meh
Additional Comments: lga2011 for upgrade path.
want top of the line ssd 60 or more gbs but speed and reliability are most important.
i have three ide hard drives so i want to find a way to add them in the lga2011 none has ide
i can buy now and add parts later but want it in a working state so add slash swap gpu add ram, fans later
so what my idea so far is
case:like the air flow and the ez to get to my cords with the 90 dgree angle
SILVERSTONE RAVEN Series RV03B-W Matte Black Steel / Plastic ATX Full Tower Computer Case $147.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163180
gpu: no clue just needed a passable one for now can swap add lator 1 gig and dvi needed hdmi is a plus
EVGA 01G-P3-1361-KR GeForce GTX 460 (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card$149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130749
ram:atleast four usable but want to be able to end up at 8 or more at some point
G.SKILL Ripjaws X Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9Q-32GBXL $279.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231487
mb:lga2011 must would like 2 pci but not really needed but if not some way to add the ide drives more ram slots better S/PDIF Out nice and e sata nice
i think my pick is crap but dont really have the info on mbs
ASRock X79 Extreme3 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard $214.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157287
psu:want more than i need plan to keep it a while reliability key
SeaSonic S12II 520 Bronze 520W Power Supply
http://www.newegg.com/Product/Product.aspx?item=N82E16817151094 $59.99
cpu cooler: good cheap noise does not bug me
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 120mm sleeve CPU Cooler $29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
ssd: fast good at least 60 gb
http://www.newegg.com/Product/Product.aspx?item=N82E16820227757
OCZ Agility 3 AGT3-25SAT3-90G 2.5" 90GB SATA III MLC Internal Solid State Drive (SSD) $139.99
cpu:
Core i7 3820 $285
and i end up a bit over budget and not sure of best way to get my 3 ide drives used and still need a dvd burner drive
Country:usa
cpu:
Core i7 3820 $285
