Hey all, I have a few problems and I cannot find a solution for them, so I thought I will ask you guys.
Here's my build
i5 2500 K, Asrock Z68 Extreme3 Gen 3, Corsair 600CXV2 600W PSU, HDD WD 1TB Blue, Cooler Master Hyper TX3 CPU cooler, Mushkin 4GB CL7, Sapphire HD 6570 GDDR5 512MB, Raidmax Altas RMX case, Asus Xonar DG Soundcard.
Now the story, I always used XP (after 2000) and never really tried Win7, now I did and I cant really understand alot of things...
1. My VGA is 512MB but when I check at "dxdiag" its between 1228 and about 1690MB, why does it take memory from my RAM ? How can I make the VGA use only its own 512MB RAM without touching my real RAMS ?
2. When I check my PC at the "System" in Win7, it says 4GB ram (1.92 usable) where the hell is the rest of my 2GB ram ? I understand my mainboard has a vga card aswell, and when I go into CPU-Z, at graphics, it tells me this. HD6570 788 MB, and Intel HD 2000 GT2, 512 MB. How can I disable the onboard VGA card ? In bios I have PCI-E as first GPU.
3. In the bios I set the multiplier for the CPU at 45x and at boot it says the CPU is running at 4500mhz, but CPU-Z shows 1600Mhz @ x16 multiplier, and sometimes it jumps to 45x then back to 16x, is it a CPU-Z bug or the CPU is not running on a stable 45x ? Asrock Extreme Tuner also shows 45x, and its running at a cool 35-40 degree C. At first sight overclocking is easy, just set to 45x, put the ram to 1600Mhz and its done... is there anything else I need to do ?
4. How can I make the Win7 not "waste" any RAM for stuff like VGA card, onboard VGA or anything at all really ?
5. My HDD is really slow, copying a big file cannot ever reach 50mb/sec (just in the beginning), it goes around 30-40MB all the time, but the most disturbing thing is, whenever I use a torrent client like uTorrent and I download, after 4-5MB/sec speed, it says disk overload and the speed keeps falling, like the HDD couldnt handle the speed...which is ridiculous at 5MB/sec speed. Also when the torrent is going and I open a movie or an SQL (or any heavier program) the disk overload stars and the speed falls down... what should I do ? The HDD cannot possibly be that bad, I just cannot believe that simply, this must be something with Win7 or the torrent client, but what is it ?
These are my problems, the PC is 1month old, just had no time to check for these things, if anyone could help I'd appreciate it alot.
Thanks for reading!
Here's my build
Thanks for reading!
