Full tower case suggestions, I need help
Last response: in Components
I currently have a mid tower case and am looking to upgrade to a full tower case so I can Crossfire a couple 6970's, only 1 fits in my case. I have two cases in mind, if someone could recommend one of them. I am also open to other cases if someone has a better option. Money isn't a big deal to me.
Here are the two cases I have in mind:
Corsair Obsidian Series 800D
http://www.corsair.com/pc-cases/obsidian-series-pc-case...
Thermaltake Level 10 GT
http://www.thermaltakeusa.com/Product.aspx?C=1416&ID=20...
More about : full tower case suggestions
I like either:
COOLER MASTER HAF 932 Advanced
$130.00
or
COOLER MASTER CM Storm Series Trooper
$150.00
$130.00
or
$150.00
Related ressources
- Need Help choosing a Full Tower Case £180 Budget. - Forum
- Good Full TOwer Case less then $150 help ! - Forum
- Best Full Tower Case <$150? Ordering Tomorrow! HELP - Forum
- need a full tower , great cooling case , any suggestions ? - Forum
- Looking for the best full tower case . Suggestions ? - Forum
HAF X yeah its in your face and ugly but in an great in your face look at me way (I just aquired one and love it) I think the HAF 932 looks a bit like the X's bucktoothed cousin
or if you like things a bit more elegant this looks good i nearly got it.
http://www.specialtech.co.uk/spshop/customer/Xigmatek-E...
Xigamatek Elysium
Xigamatek Elysium
I personaly love cleaner looks over funky looking cases.
So if your somewhat budget constricted
Corsair 300r is not a full tower but it should be able to acomodate crossfire.
you also have fractal design Core 3000 or the Arc midi in the same price range.
If your not constricted by a budget... Corsair 650D would be the only choice i would consider...you not getting much more past that price range anyway, and it should provide alot of space
corsair obsidian 800D is a great case.no lack of air flow and it's good looking too.but if you want something really sweet then go with silverstone fortress.
and if you have any doubts regarding space then.......
nuff said!
nuff said!
a few more-
I probably should have put this in at the beginning, I need room for these components:
http://www.corsair.com/us/cpu-cooling-kits/hydro-series...
http://www.arctic.ac/en/p/cooling/vga/376/accelero-xtre...
http://www.pcpower.com/power-supply/turbo-cool-1200.htm...
I plan on putting two 6970's in crossfire with that cooler on each of them. The reason I had the two cases kinda picked out was they had room for the psu and graphics plus easy spots for the radiator.
first,you don't 1200w!quality 850w is more than enough.
antec DF-85 is a great case and will fulfill your needs without making a hole in your pocket.you can fit the h100 on top and it has enough room and airflow for your graphics cards.the case has great build quality,airflow,plenty of room and looks really good.
I didn't say earlier as I'd thought we weren't suggesting other cases,
but
http://www.tweaktown.com/reviews/3851/in_win_dragon_rid...
is a good fulltower
Moto
but
is a good fulltower
Moto
hellfire24 said:
he has a complete build log-http://www.tomshardware.com/forum/forum2.php?config=tom...
enjoy!
Its called sarcasm ...... google it lol
^$280( http://www.newegg.com/Product/Product.aspx?Item=N82E168... ) and you call it 'on a budget'?
well i don't think so.
kubi01 said:
I currently have a mid tower case and am looking to upgrade to a full tower case so I can Crossfire a couple 6970's, only 1 fits in my case. I have two cases in mind, if someone could recommend one of them. I am also open to other cases if someone has a better option. Money isn't a big deal to me. Here are the two cases I have in mind:
Both of the case are ultimately superior in their design and performance.
I would like to add more chassis for you that is also a superb seller in the world:-
Cool Master :-
HAF X Nvidia Edition
http://www.coolermaster.in/product.php?product_id=6678
HAF 932 AMD Edition
http://www.coolermaster.in/product.php?product_id=6632
HAF 932(Best seller)
http://www.coolermaster.in/product.php?product_id=5363
Now you have total of 5 chassis from which you can pick any one they are been marked as the best.You will not regret after choosing among them at all later.
I recommend you to go with HAF 932 AMD Edition because you will crossfire and will give a better label and look for your crossfire cards.
there a lot of other cases that provide similar(or better)performance for less price.for example,nzxt phantom and carbide 500r.
how? and it's no longer available for sale.
hellfire24 said:
there a lot of other cases that provide similar(or better)performance for less price.for example,nzxt phantom and carbide 500r.They are newly launced once and I have recommended you the once which are already acquired a huge market.
AMD is referring to the ATI cards so for your Crossfire setup It will be a really nice one.
Oh! Out of stock.No idea about it.
hellfire24 said:
^don't you think it's better to buy something new and different(reliable and solid performer OFC)instead of what most of the people already have?Yes,its always better or good idea to purchase new one but many of the people like to purchase products which already are pretty much spread(purchasing depends on the person to person).
If you like to go with the new one then also it is a good choice.
Motopsychojdn said:
Btw Op, what Mobo are you on and are both your cards the same make? you said 'only one fits'?Moto
My case isn't big enough that is all.
I am leaning toward the level 10 GT. I have had a couple of their cases and have really liked them. I like how big it is, plus the ease of radiator placement and side fan. Thanks for your responses, I am going to buy it unless someone can convince me otherwise.
hellfire24 said:
^level 10gt is one of the worst case for liquid cooling,i agree it has got great looks and all but if you are thinking about ease of radiator placement,then forget about it.http://www.youtube.com/watch?v=u_76-Ca8jRQ
5:30 it seems to fit easily
Related ressources:
- ForumFull Tower Case Suggestions
- ForumCase with best cable management? ( full tower only!)
- ForumAnyone have a release date on Corsair's new full-tower case ?
- ForumChoice of a Full Tower + Power Supply - Need help !
- ForumBest full tower case
- ForumNeed Advice on Choosing a Full Tower ~ Filters and Such
- ForumDo I need Full or Mid Tower ATX Case
- ForumNeed good full tower case
- ForumNeed a Full tower case for less than $100 dollars
- ForumNeed advice on Full Tower
- Forum212 evo fan replacement
- More resources
Read discussions in other Components categories
