Building 1800ish$ system, need advice! (first build)
rolfsnuffles
Hello,
I am building my first desktop with a little help and encouragement from a friend, and he recommended this site for final advise on comparability/performance. I'm building a new gaming computer with roughly 1700-1900$ in mind for a budget.
Here's what I have saved so far:
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
New CPU fan due to cited overheating issues with stock fan: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Tower: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128506
Hard drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136795
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371049
I have two graphic cards picked out, not such which is better for my current system/gaming performance:
Geforce http://www.newegg.com/Product/Product.aspx?Item=N82E16814130595
Raedon http://www.newegg.com/Product/Product.aspx?Item=N82E16814161372&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
Monitor: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236117&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
Keyboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16823126199&Tpk=logitech%20solar
I am also unsure of which windows to buy, I would prefer one mounted for price, but I am open to suggestions. I'm a newb when it comes to building, and would appreciate any advise on comparability and if there are better/cheaper parts that will perform just as well as what I have rounded up. My friend has a mat and static protector.
Thank you for your time!
tlmck
tlmck
i7-2600k does indeed have Hyperthreading, but it still does not benchmark significantly better for gaming applications. Certainly not worth the extra cost IMO.
It is true that the HDD is larger capacity, but quality on Hitachi is suspect at times. Not that WD is any great shakes either these days, but it is still better than Hitachi. Still, with the shortage, you have to go with what you can get.
I would also check the motherboard compatibility with Patriot ram. It can be a bit ticky.
And if Microcenter is in the mix, the i5-2500k can be had for $179.99.
