Case Front Intake Fan Question?
Last response: in Components
Hi everyone.
So basically I bought this fan:
http://www.ebay.co.uk/itm/EZcool-140mm-Fan-Super-Silent...
It comes uses standard 4 pin molex.
I have a NZXT Phantom full tower case, I bought that as an intake fan, if I use molex power, the LED will always be on, and I won't be able to use the fan controller.
So is this what I need to convert it to 3 pin? So that I can use it with my fan controller?
http://www.ebay.co.uk/itm/4-Pin-Molex-male-female-3-Pin...
There's also this which is cheaper, so I'm wondering if it does the same thing?
http://www.ebay.co.uk/itm/Molex-4-Pin-Power-Cable-3-Pin...
Thanks!
Sure, on the 2nd link.
But are you sure it comes with a Molex plug only? Most fans come with an adapter to turn the 3-pin (to motherboard or fan controller) to a 4-pin Molex (to power supply).
You are going the other way: 4-to-3.
So both of the adapters in the links are fine?
It doesn't state if it includes it, I'm not going to wait for if to come then order an adapter, I wanna be able to get it all set up at once.
Ask the community
