Finding a PCI sound card with SPDIF?
Last response: in Components
- SolvedBest Sound Card with S/PDIF Output Under $100? Forum
- SolvedConnecting a sound card to your video card via SPDIF connector Forum
- Solved7.1 SPDIF Output Sound Card Forum
- SPDIF not working on MOBO/Sound Card, was working before. Forum
- HTPC Audio over nvidia card 8500GT spdif from sound blaster Forum
- Sound card to receiver S/PDIF not working (no sound). Forum
- PCI / PCI-E card with SPDIF in & out Forum
- Using 3.5mm spdif_io from sound card to 3pin pdif_in on 8400gs Forum
- Which SPDIF out sound card? Forum
- Internal Sound Card SPDIF 5.1 output Forum
- SPDIF from sound card issue. Forum
- Physx card and cheap card with sound w/o spdif advise Forum
- SPDIF pin out on a cheap sound card: please recommend Forum
- SolvedHelp finding a PCI wifi card? for gaming reliable??? Forum
- spdif quality on sound card Forum
- S/PDIF sound card Forum
- SolvedZalman CNPS9900, Asus Xonar D2X 7.1 PCI-E Sound Card with the ASRock 970 Extreme4 mobo? Forum
- SolvedNeed help finding the right PCI card. Forum
- SolvedNeed suggestions for a PCI Express x1 sound card Forum
- SolvedInternal PCI Sound card or USB Sound card? Forum
- More resources
Read discussions in other Components categories
