Issue with 8800 GT in SLI... need help
I noticed my XPS 630 wasn't running my 8800 GTs in SLI so I went to enable that feature in the nVidia software... but there isn't an option for it. Also, there is only one 8800 GT shown in the device manager.
I did remove them a few weeks ago when I was cleaning out dust bunnies, I checked and each is seated properly and the SLI cable is good.
Any idea what might be wrong? Which PCIe express slot do I use to check each card at a time to see if one of them might be bad? It's a nVidia 650i SLI mobo.
Sorry for the noobness...
2 answers Last reply
More about issue 8800 help
  1. Ok. I tried each card alone and the first card was fine. System booted ok. But when I tried the 2nd card (in the same PCIe slot) I got about 8 fast beeps that repeated when I powered up.
    Does that mean that card is junk? Thanks.
  2. It was 6 beeps... and the means "Video BIOS Test Failure"...
    I'm guessing that isn't repairable?
Graphics Cards Device Manager SLI Nvidia Graphics
