Hi guys. I have a monitor (1900x1200) and TV (1900x1080) hooked up to my Windows 7 PC via hdmi cables. Is there a way to switch my main display over to my TV so I can play games/watch videos on my TV instead of my monitor? Currently I have it set to to extend by default, then when I turn on my TV I press Windows + P to switch over my TV as my main display (then switch back to extended when I'm done).
However when I do this, it seems to still try to display 1900x1200 on the TV and as a result it is missing some lines from the top and bottom of the screens (e.g. the taskbar is halved in height and if i full screen youtube the playback bar is missing). Is there a way to fix this resolution issue, or a is there better way to switch displays (eg. third party app)? Could it be related to upscaling? I have a radeon 5870 running the latest drivers, if that helps. I don't need to have both screens working at the same time as they are quite far apart so its not really possible to use both at the same time. Thanks!
