Using standard handset as terminal device
Last response: in Technologies
Archived from groups: alt.cellular.gsm (More info?)
Hi, folks--
I'd like to set up one of our servers here to monitor our computer networks
and send short text messages to one or more of our techs' cell phones in
case of problems. Seems like the "right" way to do this is with a terminal
module-- I was recommended the Siemens MC35i, but this is Telcel land
(Mexico) where I can pick up a basic GSM handset pretty easily, but they
don't have a clue about dedicated terminal devices. Handset models I'm
looking at are Siemens A56 and A55, and Nokia 1100,3100,3595,6100; anybody
know whether it is feasible to hook one of these up via RS232 to a computer
and control it to send text messages?
Also, if I get a handset to play with and manage to obtain a terminal
module, can I just put the SIM card from the handset into it and have it
assume the personality of that phone? Sorry about my ignorance on how these
things work, I'm new to the GSM world...
Thanks-- Larry
Centro de Investigaciones Biologicas del Noroeste,
La Paz, Mexico
Any handset would work, as long as it's got a built-in modem module. Most
of older GSM handsets do, many newer models don't. Check the phoine's
manual to find out.
You would be better off using a USB cable if it's a Windows computer. Find
the variety that charges the handset's battery. On a Comport cable you may
have to do some soldering to connect the charger.
Modules are better for high-volume traffic, otherwise the handset's just
fine.
Yes you can place the simcard into a module or another handset and it would
work, provided that the new device isn't locked to a carrier other than
yours
> Hi, folks--
networks
terminal
computer
these
> Thanks-- Larry
> La Paz, Mexico
And a little-known fact: many GSM networks block text messages cycling to
the same number. You may not be able to send more than 10 to 12 messages in
a row to the same number. It the spacing between messages is 10 to 20
minutes, or you use several receipient numbers it would work just fine.
> Hi, folks--
networks
terminal
computer
these
> Thanks-- Larry
> La Paz, Mexico
"Larry Miller" wrote:
> Hi, folks--
> computer networks and send short text messages to one or more
> with a terminal module-- I was recommended the Siemens MC35i,
> but this is Telcel land (Mexico) where I can pick up a basic
> models I'm looking at are Siemens A56 and A55, and Nokia
> 1100,3100,3595,6100; anybody know whether it is feasible to
> hook one of these up via RS232 to a computer and control it to
> send text messages?
I don't know about those particular Nokias or the Siemens A56,
but the A55 doesn't have an inbuilt "modem" capable of sending
SMSs via the serial port. However, an A55 can be
firmware-upgraded to a C55 (which does have the modem) using a
procedure sometimes described on newsgroups.
The cheapest handsets tend not to have inbuilt modems.
You should also note that there are 2 common modes for the
interaction between GSM device and computer when messaging over
a serial connection: text-mode and PDU-mode.
Text-mode allows you to send clear text across the serial
connection, whereas PDU-mode requires encoding/decoding at the
PC end. "hello" in text-mode is "E8329BFD06" in PDU-mode, so
you'd need to incorporate the conversion algorithms in your
software for a PDU-mode device. Text-mode GSM devices do the
conversion internally.
Siemens handsets are PDU-mode-only devices, but their terminals
support both modes.
Ashot's point about providing power may be an important factor
in favour of using a terminal instead of a handset. Depending
on the fine details of the charge-termination algorithm, a
handset battery on constant charge may have a very short life
indeed.
> terminal module, can I just put the SIM card from the handset
> into it and have it
> ignorance on how these things work, I'm new to the GSM
> world...
In that direction, yes, but a locked handset may not accept
another SIM.
John
Related ressources
"Ashot Shahbazian" <tyrebusters(at)covad(dot)net> wrote in
news:4950d$4113d32b$40694c09$24995@msgid.meganewsservers.com:
> Most of older GSM handsets do, many newer models don't. Check the
> phoine's manual to find out.
Thanks. I'm confused. Is a modem used for SMS messages? I thought that
was some digital protocal between the phones. Or is it that the modem is
required for the PC to phone communications?
Nah, we work in Unix here for the server side stuff. Good point on the
battery and charging issues, hadn't considered that.
> would work, provided that the new device isn't locked to a carrier
> other than yours
Good news, thanks!
--Larry
news:54c$4113d40a$40694c09$25280@msgid.meganewsservers.com:
> to the same number. You may not be able to send more than 10 to 12
> messages in a row to the same number. It the spacing between messages
> is 10 to 20 minutes, or you use several receipient numbers it would
> work just fine.
Sounds like a useful mechanism to prevent abuse, but I kinda doubt Telcel is
that enlightened. :>
--Larry
John Henderson <jhenRemoveThis@talk21.com> wrote in news:2ni9qmF182s2U1@uni-
berlin.de:
Good to know, but no problem as long as we have the specs.
> support both modes.
Thanks. After reading y'alls comments I'm even more convinced that a
terminal is the way to go, but have a bit of a supply problem here in
Mexico. Anybody know of dealers for (preferably) Siemens terminals in the
southern U.S.A. or Mexico?
>> into it and have it
>> ignorance on how these things work, I'm new to the GSM world...
> another SIM.
Not much worried about that. The packages that Telcel sells pretty much
give away the handset and I'd just consider it a disposable carrier for the
SIM which would be destined for the terminal module. :>
Now the question is where to get a terminal module here in the Americas.
Seems like Siemens has much better represantation the other side of the
pond...
Thanks-- Larry
> thought that was some digital protocal between the phones.
> Or is it that the modem is required for the PC to phone
> communications?
"Modem" is something of a misnomer in the context of a GSM
device. It's more like a general purpose command interpreter
for the "AT+C" cellular extensions to the standard "AT" command
set. Usual functions include establishing data calls (ISDN or
"analog"), messaging (2-way SMS and the reception of cell
broadcasts), and perhaps GPRS connectivity.
John
> ... no problem as long as we have the specs.
They are available as PDF files (download free after
registering) from www.etsi.org. I'd suggest starting with GSM
specs 07.07, 07.05, 03.38 and 03.40. Go to the download area
(Services & Products), search for each by number, and download
a recent version from the unsorted list.
> that a terminal is the way to go, but have a bit of a supply
> problem here in Mexico. Anybody know of dealers for
> (preferably) Siemens terminals in the southern U.S.A. or
> Mexico?
Try http://tinyurl.com/4p7jh.
John
John Henderson <jhenRemoveThis@talk21.com> wrote in news:2nsr69F42eq1U1@uni-
berlin.de:
>> communications?
> set.
Ah, very clear-- thanks. Is that a standard command set for the extensions?
--Larry
John Henderson <jhenRemoveThis@talk21.com> wrote in news:2nss22F4epc7U1@uni-
berlin.de:
Oooh, what a wealth of information. :>
>> Mexico?
Very nice. :>
Thanks a bunch-- Larry
berlin.de:
A wealth of information. :>
>> Mexico?
Very nice. Mmmm, now why didn't I find that? :>
> the extensions?
In general - yes. Implementations of AT+C commands are standard
across manufacturers, but I need to qualify that immediately.
Many individual commands are optional, or mandatory only if
certain other optional commands are implemented. And the spec
for some commands gets interpreted slightly differently by
different manufacturers occasionally. An example might be
where a null value for a parameter means "all possible values"
to one manufacturer, and "no values" (disable the feature) to
another.
GSM 07.07 has a very useful section on the syntax of AT+C
commands, and details the means by which you can query the
device's implementation, and permissible range of values.
Manufactures often add their own proprietary commands, using a
different command prefix. Siemens-specific commands begin
"AT^S" instead of "AT+C".
John
> Mexico?
You might want to consider Wavecom GSM terminals:
http://www.wavecom.com/home/XMLindex.php.
They seem to better regarded than Siemens, since Siemens
reputedly outsourced firmware development. If I was buying one
today, I'd go for the Wavecom (although I haven't used one).
John
John Henderson <jhenRemoveThis@talk21.com> wrote in news:2nvg4qF582soU1@uni-
berlin.de:
*Very* interesting. And they have a branch in San Diego. :>
Thanks for the info! I'll contact those folks.
--Larry
I've decided I'll probably buy a Wavecom unit myself soon
(Fastrack 1206). Looking at the specs though, I'm not sure
that Wavecom offer much for the 1900 mHz band used in
Mexico/USA.
John
John Henderson <jhenRemoveThis@talk21.com> wrote in news:2o28qqF67hi5U1@uni-
berlin.de:
> Mexico/USA.
Well, I'm glad you mentioned that-- I'm very embarrassed to say I missed the
frequency detail and was looking at the 1206 myself, which would have
obviously been a problem. :-\
They do have the Q2426 module which runs 850/1900 mhz.
From what I can see, nor does Siemens offer a 1900 mhz terminal though they
have several tri-band modules which can be integrated. Mmmf, that adds a
level of complexity that I hadn't anticipated.
Wonder why these folks aren't (don't appear to be) offering 1900 terminals.
Seems like a useful niche...
Thanks-- Larry
berlin.de:
> Mexico/USA.
I've just been informed by the Brazilian Wavecom distributor that Multitech
is producing a 1900 mhz terminal using the Wavecom hardware. Following that
lead now... :-}
Thanks-- Larry
Ask the community
