There are various wires/cables that connect my PC power supply to the motherboard, hard disks, etc. If I replace the power supply can I just disconnect the existing cables from the current power supply and connect them to the new power supply or will the new power supply have its own cables that need to be used to connect it to the motherboard, hard disks, etc.?
A couple of other questions.
Do the mini-tower PCs use the regular size power supply or do they use a smaller one?
Which cable extension should I purchase to extend the existing power supply fan speed monitor connector cable? It comes out of the motherboard whenever I remove the power supply (to work on it) and it is very difficult to put it back in.
Thank you!
Thank you!
