I have just about completed my build, just waiting on an Ivy Bridge CPU.
I have the CM Storm Trooper case (http://www.newegg.com/Product/Product.aspx?Item=N82E16811119245) which has 4 case fans and has a fan controller built into the front panel.
I also have the ASUS P8Z77-V PRO motherboard (http://www.newegg.com/Product/Product.aspx?Item=N82E16813131819), which has 4 - 4 pin fan connectors. It has ASUS Fan Xpert 2 to control the fans.
So I wanted to ask about the advantage of using the fan controller in the case vs. the one built into the motherboard. Using the case one would only allow me to adjust the fans manually from the front panel I assume. This is my first motherboard with fan control built in, so I don't know what ASUS Fan Xpert 2 allows me to do. I'm hoping it measures the temperature and runs the fans only as fast as required to cool it to a safe level.
The fans have a 3 pin header which seems to be able to either plug into the 3 pin connectors from the case fan controller or into 3 pins on the 4 pin headers on the motherboard.
Any recommendations in which way to go?
Thanks.
Thanks.
