Hey,
This is probably not the right place to put this but anyway....
I have just built a second system the basis of which is an AMD A8-3870 and the Gigabyte A75M-UD2H!
The wireless connection is incredibly slow and continuously disconnects. Its so bad it takes about 30 mins of constant trying to load this website. The adapter I am using is the Edimax EW-7711Usn!
This adapter is the one from my main rig and it works absolutely fine, the PC's are also the same distance from the router and the aparent reception is the same. I have tried with both the default windows drivers and the correct ones from the manufacturer.
I am completely lost!! Any ideas where the fault could be??
Thanks.
Thanks.
