Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > TV Tuner Cards > What's the point of more than 1 monitor?
Forum Graphics & Displays : TV Tuner Cards What's the point of more than 1 monitor?
What's the point of having more than one monitor? Do note that I have zero experience with multi-monitor setups (don't have the funds or the space and stacking 40-pound monitors on top of each other is another issue). While I think I understand that multi-monitor setups allow for a higher resolution experience, such as connecting two monitors of 1920x1200 to get either 3840x1200 or 1920x2400 resolution. Still, there's that gap between the monitors that might cause workability problems. You could get 3 1920x1200 monitors for the price of a single 2560x1600 display and get far more total pixels. Beyond that, what's the point of having several monitors?
Reply to ulillillia
I have run dual displays for years
would never go back
I run 1920x1080 21.5 primary
and a 1280x1024 secondary (saving up for new monitor)
for me it is the abiltiy to have a multiple apps open between the two displays
for example an email open with a two or three browsers plus MS Word etc
so if I have info on an email that plus on browser windows I can
easily see it as I type on MSWord
also I put my Outlook,system monitor, on there so I can see it
and not take up space on primary
for example while typing this
I have TV playing in Cyberlink Power Cinema from my TV capture card
I have outlook
I have DVD Flick encoding/burning a DVD
and I have HWinfo64 showing temps and clocks
while I have two big browser windows on primary
one is my toms
the other is ebay
It has been stated by Microsoft that having multiple displays
can increase work productivity by 30-40 percent
plus it looks cool :)
------------------------------ "I yam what I yam and thats all that I yam"-Popeye-greatest 20th century philosopher
[http://valid.canardpc.com/cache/banner/2375043.png
Reply to king smp
^^^ +1
When I use multiple monitors it's usually for when I do multimedia work. It can be handy having Dreamweaver open on one monitor and the page in a web browser on the other so I can quickly view it. If I'm doing video work I might have my controls and timeline on one and the composition and video on the other.
If I play games (since I have a laptop) I might have temps and usage meters on one screen whilst I play on the other.
Reply to sam_fisher
Also for gaming you can actually see more. Check out this link, it is a demo of eyefinity.
http://www.amd.com/us/products/tec [...] inity.aspx
Reply to dontqqnub
I first used more then one monitor back in my college days. I hated having to work in the lab with the rest of the group because my rig at home had dual monitors. The ability to see example code on one screen while writing your own code is worth every penny. Sure you can do it on one monitor sort of, but you spend a lot of time minimizing/maximizing windows. Trust me, those wasted seconds add up. For productivity multiple monitors are a must.
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
I have played World of Warcraft on one monitor, while streaming a movie/tv show on the other monitor.
Also for photoshop I keep 1 monitor with the picture i'm working on and then on the other I have all my tools and file browser open, and I sometimes stream a movie while working on some projects.
Reply to sceen311
I am saving up for an Eyefinity setup myself (HD 5670)
I dont want it for gaming
I need it for applications
"Desktop real estate" has become a catchphrase for a reason
I even did it back in the old CRT Tube days
takes up alot of desk
but once you set it up
you will hate working on one monitor
if you have the time read this
http://en.wikipedia.org/wiki/Multi-monitor
Reply to king smp
The point is that if you dont have virtual desktops, you need dual monitors
------------------------------ Yes, I am a switcher
Reply to leandrodafontoura
I tried a couple of different virtual desktop apps over the years
and never liked them
I am not that smart so I get confused with them :)
Reply to king smp
I don't do gaming, though I do game design, which is a totally separate thing. I don't do any demanding stuff so my GeForce 7600 GT is barely a problem. Even for productivity, I don't see much use in multiple monitors, unless running a program in full screen mode and you need to shut it down (such as it crashing or freezing (the latter often due to unresponsiveness or infinite loop bugs).
Afterall, I can have the image window of GIMP positioned in a way so that I can reference calculations I've done in Excel behind to position things (since it's faster that way than to spend a while writing a program for something otherwise short but accuracy-critical). I run at 1920x1440 resolution on a CRT, so I find plenty of space, especially the much-needed vertical.
I'd love to go with 2560x1600, but at over $1000, it's not worth it. I can buy 6 of my 1920x1440 CRT monitors for that price, even with the hefty $40 shipping for each monitor.
I asked this as I was seeing some threads stating of having 5 monitors, of which I thought someone was going berserk on monitors, as if collecting them.
Note to mods: I accidentally posted this in the wrong category - I thought I was in the "graphics" forum, not "TV Tuner cards". I would think this thread should be moved there.
Reply to ulillillia
chances are that if you are asking this question, you probably wont need a multi monitor setup.
Reply to mayankleoboy1
my first build was for video editing and had 2 17" CRTs (later upgraded to 19" Mitsubishis woot!) plus a TV. Premiere felt much less cramped across 2 screens, and the TV was for a live preview of what I was editing so I knew exactly what I was getting.
About 4 years ago the old CRTs started getting blurry and I decided on a single 27" as it was large enough to have 2 pages up at a time at 100% zoom (meaning they are life sized), and it has been nice, but I would love to have a 2nd, or even 3rd 27" monitor if the budget afforded it.
If I had my way now I would have premiere over 2 1920X1200 screens, and then put the video feed on the 3rd so that I can have a fully uncompressed view of what I am editing again. Plus it would make for some nice surround gaming, but I would have to get SLi running before that happened.
It takes some getting use to using that much space effectively, but the same law that causes all flat surfaces to be covered with clutter applies to monitors as well; you may not know what you would use the space for, but once you have it there is still not enough!
------------------------------ PC: ASRock Extreme3 Gen3, i7 2600, CM Hyper 212 EVO custom fans, 16GB Corsair XMS3 @ 1333, GTX 570, OCZ ZS 750W, 2.5GB HDD Space, Thermaltake V3 Black Edition, Hanns-G 27", Win8CP 64bit
GPUs: http://www.tomshardware.com/review [...] cs-card-re
Reply to CaedenV
To each their own but
if you never have tried dual monitors
and it is possible to try it you should
I have a 1920x1080 and feel cramped when I have the second display
shut down and only using primary
I am also in the USA so it is cheap to get monitors
I have a 1920x1080 Viewsonic VX2260WM 21.5 inch 16:9 I bought
used a year ago on Craigslist for $90 with DVI cable included
and a 1280x1024 17inch gateway I bought for $15 at a secondhand store
I always buy my monitors used
Though for true color portrayal I have heard the CRTs are actually better than LCDs
and I had a Mitsubishi Diamond Pro 22inch CRT that I ran for years and didnt give it
up until it broke last year
I loved that screen
I hated moving it LOL
Reply to king smp
My super high 1920x1440 resolution pretty much makes up for the use of multiple monitors in many ways (and even then, I still don't find that that resolution is high enough). I barely have enough room on my computer desk for doing maintenance, let alone putting my 1600x1200 CRT monitor that's been collecting dust for about 3 years now to work.
Thanks for the responses though - I've always wondered this for several years.
Reply to ulillillia
For code monkeys I have always heard that it is nice to have 1 normal monitor to preview their programs, and use for normal things, and then another wide screen monitor in portrate mode so they have tons of vertical space to code on.
Reply to CaedenV
"It takes some getting use to using that much space effectively, but the same law that causes all flat surfaces to be covered with clutter applies to monitors as well; you may not know what you would use the space for, but once you have it there is still not enough!
truer words have never been spoken
Spend one month using dual monitors and then try to go back to single
but also if you are happy
then dont worry about it :)
Reply to king smp
lol, I hear you king, those mitsubishi monitors are beast. Even my 19" ones were at least 50lbs each. When I moved east I gave them to my dad, and just moved back to my old 17" envision monitors. I never bought a monitor until my big LCDs. I got all of the CRTs for free from business closures by just showing up and asking if they had anything they would want to give to a poor starving high school/college student; oddly that argument holds less weight when you get older. Now I can get all the screens I want at my work, but I am addicted to the larger screens as my setup sits on a coffee table ~4' from my couch. It is just too hard to see small dense pixles at that distance.
Reply to CaedenV
Great for programming <3
Reply to amuffin
I had a Dual of 19s at work for more than 4 years now.... but never really felt I wanted to get into it at home since I already a 24 sitting on my desk, although I've had an extra 24 lying in it's box for over 2 years had bought them together, so recently about a month ago, I just got it out for kicks and put it on..... now I hate going to work 'cos of the 19s there and 2 24s at home.....
------------------------------ Passiveness causes others to pass us by
http://valid.canardpc.com/cache/banner/2026250.png
Reply to alyoshka
I am glad to help
But remember if it your setup is working for you then it doesnt matter
about the second monitor
A computer is a tool designed for certain purposes
If it serves that purpose then there is no reason to change the computer
If it isnt broke
then dont fix it
It was definitely a good question for a thread
It is 3 am
I should go to sleep LOL
Goodnight
Reply to king smp
I disagree. Some things are worth trying, this is one of them.
Get a bigger desk.
Always a DEMON!
Reply to 4745454b
I've never experienced a dual monitor setup so, obviously, I'm used to a single-monitor setup. The super high resolution I use otherwise makes up for it for the most part. I just can't test in fullscreen effectively, but that's otherwise a minor issue as windowed mode works just the same. I have at least learned quite a bit from this thread. Still, being used to only a single monitor, it's likely what I'll intend on doing.
I only have 2 upgrades in mind. The first is my video card, since it can't play back H.264-encoded HD video in Virtual Dub at true speed as it can't decompress fast enough. The second is the RAM and CPU fan - I'd like to upgrade these. It takes a long enough time to save up as it is.
Reply to ulillillia
The very first time I ever used a 2nd monitor, I marveled at just being able to have Task Manager and GPU-Z open on one monitor while I was gaming on the other. Though it's incredibly helpful in a lot of other usage scenarios already pointed out by earlier posters.
WQXGA and WQHD monitors would also help immensely for multitasking but are priced out of most people's budgets. I'd love to save up get a Dell U2711 someday...
Dual 1080p monitors give a tad bit more pixels at a much more affordable price and I think that is the preferred method for those that are serious about productivity or those that just want the better experience that it provides.
Reply to stonedatheist
Get a bigger desk.
I highly agree with the quoted comment, multi-monitor setups allow for much more productivity.
I know you don't game but for gaming purposes multi-monitor setups own single monitor in every possible scenario.
"two is better than one"
Message edited by dontqqnub on 11-12-2011 at 10:12:17 AM
Reply to dontqqnub
Actually gaming is best on 3 monitors and Flight Simulators are best on 9.....
2 Monitors aren't the best for gaming, they are the best for productivity though. You can compare it to tabbed browsing vs single window browsing, with a dual setup you have more parallel work being done, it a real boon for multi tasking brains simultaneous references and editing, drawing, creating, watching, entertainment, taking a break..... it all just adds up to a second monitor.
Why even watching a HD movie is a real experience in a 2 or 3 monitor setup with a good audio system, you'll really forget the Theater experience. The best parts are the bezels, the marvelous human brain and optic system just minus the bezel after a little while..... it's an amazing thing , and really if you have the dough , it's worth every penny....
Reply to alyoshka
I'd like to add that there is no shame in using only one monitor. I don't do any real work on my computer anymore and get along with only one monitor just fine. I would like to run a 3x1 eyefinity setup, but TF2 looks horribly stretched.
If you do a lot of real work, you should run at least two if not three screens. If you just play games or watch tv/movies, one is fine.
Always a DEMON!
Reply to 4745454b
Two monitors are great in my opinion, I like to have one available so that I can browse the web or call/chat with people while playing a game.
If you are asking about Eyefinity and gaming... yeah not my cup of tea at all. With a giant monitor it would obviously be great but the typical eyefinity setup with 3 monitors completely destroys immersion for me due to the borders cutting through the image.
Reply to Xolotl_72
Just wondering here, how many people who say the borders ruin thing have actually ever used eyefinity? I had a monitor with a chip in it once. If you looked for it you could see it. But once you started playing, you wouldn't notice it at all. Similar for Eyefinity. Sure if you for the lines you can see them. But considering those other monitors help form your left and right views, I'm sure your brain wouldn't care.
Always a DEMON!
Reply to 4745454b
looking at your configuration
your video card upgrade is your most important
and trust me I know all about taking a while to save up
took me months to get my $80 HD 5670 LOL
and you have a great CPU (2600k)
so eventually when you get your new video card your system
will be top of the line
if you ever get a chance ot do a second monitor
I think you would like it
but not a priority
Reply to king smp
Mmmm, yeah, that is kinda what I was thinking. If you have to ask "whats the advantage of multiple monitors?" you apparently do not understand the very basic function and simple revelation that the OS "Windows" brought to the table in the first place.
However, the question has opened an interesting discussion.
------------------------------ i7 2600k @4.4Ghz | ASUS P8P67 Pro | 8G Corsair Vengeance 1600mhz DDR3 | 2-EVGA 560ti SC SLI | 60GB Corsair Force 3 SSD | 1TB Caviar Black | AX750 Corsair Gold Rated PSU | CM HAF 922 | HP 2509m HD LCD 1920x1080
Reply to jitpublisher
@ ulillillia
Check your PMs
I sent you one
King SMP
Reply to king smp
I Run Dual Monitors Myself, Before Then I Always Asked Myself; "What The Point Of Multiple Monitors", But When I Went With Dual LCDs (Orginally A SGI 1600sw And A Gateway 17", Now A 20" Dell 2001FP And A 19" Sanyo HDTV-Monitor) I Was Like "WOW, This Is Very Handy" Point; JUST DO IT!, LOL
But As For CRTs In 2002 I Bought My First LCD And Never Looked Back Ha!, A CRT Is So Last Century, I Absulutely Hate Them Now Even At 85Hz AHHHHHH MY EYES IT BURNS!!! And Holy Hell Moving A CRT Is A Biatch, There Also Unsightly, take Up Way To Much Space And Feel Like Your Looking At An Elecrtic Heater On Full Blast.
Message edited by Hella-D on 11-12-2011 at 06:01:19 PM
------------------------------ AMD Phenom2 X3 (+1)2.8GHz On MSI 970X-G45@3.9GHz|8GB DDR3-1600 CAS7|GTX460SE 1GB @ 850,1700,1.9|WD 250 (Boot),RAID-0 Raptors (Games)& 500GB WDGreen (Supplamental) |Dual Monitors; Dell 24" 2407FPW S-PVA & 19" HDTV|Windows7 Professional 64-Bit
Reply to Hella-D
this is going a little OT
but read this
http://bootstrike.com/Articles/LCDvsCRT/
of course LCDs are generally the way to go
but I could find other links where
CRTs are still used by video/graphic artists due to better
image and especially color portrayal
I made the switch just last year to LCDs
and I like them
but the image quality of my Mitsubishi Diamond Pro
especially at a jacked up refresh rate
was IMHO better than my LCD in some cases
obviously HD vids look better on the LCD
but for photographs and other images
the CRT was better
Reply to king smp
I wished CRT monitors would make a comeback. At $140 for 1920x1440 resolution, you almost can't beat it pricewise. They scale perfectly well with any resolution (unlike LCDs which must either leave black borders or stretch the image (blurring it while stretching)). 1920x1440 on a CRT looks just as crisp as 1280x960, 1600x1200, or 640x480. In addition, LCDs seem to have a fixed pixel resolution of around 100 pixels per inch - my CRT is calibrated to 144 dpi so that 1920x1440 fits in a 13-1/3-by-10-inch span. The size of one of those 2560x1600 monitors would be like having a 3840x2400 resolution in that space. I actually wished I could go even finer than 144 dpi, such as 200. I am limited to a 60 Hz refresh rate though, but, like with multiple monitors, I have otherwise no experience with refresh rates beyond 60 Hz.
Due to the fact you can't buy CRT computer monitors any more from retail stores, I'm unlikely to bother with a second monitor due to the huge costs of monitors. To match or exceed my monitor's resolution, I have to pay $1000 for a monitor, rather ridiculous.
Reply to ulillillia
alot of photographers still swear by highend CRTs
but the price of LCDs has dropped drastically
and for the home user it is the way to go
if you are going to spend about a 100-150 USD
then an LCD really is a better choice
just from the size and weight factor alone
but I disagree with Hella-D
I thought looking at a CRT was easy on my eyes with a CRT
but that is with high end CRTs like the Diamond Pro and yours also
lower end cheap CRTs were lame
but at higher resolutions and higher refresh rates
they looked good
some old time hardcore gamers will still use CRTs
competition gamers even
really a matter of preference
not something scientifically measured
cant measure an opinion
Reply to king smp
To match or exceed my CRT's resolution, these monitors are all I have for LCDs. There are no CRTs available. The closest to my CRT's resolution is 1920x1200, but that's lower than what I have, and their cheapest prices are about 50% more than what my CRT cost me. Double the price for less resolution - this makes for a bad deal, very bad. This is why I'm avoiding LCDs. For the price I paid for my CRT, this is what I have available - most of this is far lower in resolution than my CRT.
I'm not buying any monitors any time soon (and by this, I mean years).
Reply to ulillillia
There are 2047 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Will this video card work on my PC..
By looniam, 4 hours ago:
no need for power connections and your PSU is ok to go with it...
Best offers
Top experts
