Will a new case help cooling alot?
Ah forgot that one. The Antec 300 is a great case also.
If your old case only has a 90mm exhaust, that case will tremendously lower temps.
GI_JONES
829
A new case with good air flow can make a huge difference. I bought a Zalman Z9plus case last weekand even though I had fairly decent airflow with my old case, this one lowered my temps even more. PhenomII X4 975 idles at 25-27C..ran a stress test with 100%usage on all 4 cores for 30 min and never went above 52C..with fans on low speed. I also have a Zalman cnps9700 cpu cooler. Anyways i am totally thrilled with the new case's performance. Here is my case..was on sale when I got it for 59.99 with free ship and an additional $10 rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235027
Uther39
To better answer your question we really need your complete current system specs ?
CPU & CPU cooler
Mobo
Ram
GPU
HDDs
Current PC case and fan set up?
carnal sage
91
oh ok.
my cpu is 2.13 core 2 duo cooler i just put in is..
Zalman CNPS9500A
motherboard is what came in my xw4400 sorry im not sure what it is..
4gb ram
card is
ATI RADEON HD 4770 512MB
1 hard drive
its the stock case that came with the xw4400 in my opinion probably horrible air flow all it has is 1-90mm exhaust and the psu fan..
Im actaully looking at this now...http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066&Tpk=Antec%20Three%20Hundred%20Illusion
Seems pretty solid
