Let's start of with these symptoms
Currently:
The cpu fan is not on although it does work because i switched the connection to the case fan and it did come on, the cpu is not on I know this because it does not get hot at all. The hard drive is on and does spin when the computer boots, the video card fan spins and the card warms up, the motherboard feels as if it is getting warmer as well, particularly on the nb connection and the psu fan does not spin.
Right before it happened:
All this occurred this morning when I went to turn the computer on it sounded like it was working but i could smell a faint burning smell. I instantly turned everything off and opened up the case. I couldnt see smoke anywhere and the smell was virtually gone. I tried to boot it again and the fans came on, the mb standby light came on and the hdd spun but there was nothing on the monitor just a blank screen.
The night before I had been playing skyrim on ultra settings with the cpu oc'd at 4.3 ghz. I was monitoring the system and the max temp the cpu reach was 50 C and the max temp the gpu reached was 61 C. I powered it off like normal and went to bed.
Past problems:
The only other problem I had with this computer was a few days ago during the build. After everything was in I went to hit the power button, with the case cover off I hit the power button and then I heard a pop and I saw it come from the psu. This was the first time it had been turned on. I tried breadboarding it and the system did cut on. So I figured it was a small short or something and put everything in the case. Up until this morning everything else was fine.
What I have done so far:
I bought a corsair ax750 psu and tried that, no luck. I took the hard drive out and connected it to my laptop and it booted up like normal. I have reseated the ram stick in every slot multiple times. I have hit the memok button but it just keeps blinking forever. I have reset the cmos and reset the bios by taking the mb battery out.
question... would resetting the mb and the cmos cause it to lose any updates to the bios, if so then the mb I am using requires an update to run am3+ sockets. Without it, it can't run my fx-4100.
There are no beeps and the system has never posted since this morning.
My specs:
M4a89gtd 890gx motherboard
fx-4100 cpu
560gtx sc gpu
corsair 4x1 vengeance
(new) corsair ax750 psu
Currently:
Past problems:
My specs:
fx-4100 cpu
560gtx sc gpu
