N naresh_49 Honorable Apr 21, 2012 5 0 10,510 Apr 22, 2012 #1 when system shows WELCOM TO XP system automatically monitor poweroff. why it happing and what i should do.
dodger46 Splendid Nov 19, 2011 4,837 1 24,960 Apr 22, 2012 #2 Have you made any recent changes? Upvote 0 Downvote
B Brett928S2 Champion BANNED Jan 3, 2012 15,316 0 52,960 Apr 22, 2012 #3 Hi Sounds like a graphics problem...try safe mode... All the best Brett Upvote 0 Downvote
suteck Distinguished Oct 3, 2010 1,292 0 19,660 Apr 22, 2012 #4 Does the monitor itself turn off or the power light just goes amber? ^+1 Safemode Upvote 0 Downvote
N naresh_49 Honorable Apr 21, 2012 5 0 10,510 Apr 23, 2012 #5 the monitor itself turn off. and even in safe mode also the same problem. Upvote 0 Downvote
N naresh_49 Honorable Apr 21, 2012 5 0 10,510 Apr 23, 2012 #6 same with safe mode. when i try to install Xp there is a message like "system did not find any harddive installed in your PC" Upvote 0 Downvote
suteck Distinguished Oct 3, 2010 1,292 0 19,660 Apr 23, 2012 #7 Can you see the hdd in the bios? Try using a different sata port. Upvote 0 Downvote
